Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Red light lit on lamp need to get at power supply
The red light is lit on the front panel.I replaced the lamp but the red light is still lit.
I suspect a power supply( capacitor) problem. where is the location of the power supply board?
I have the back panel and inside panel and insiude panel off and I can see where the p;ower cord goes but I cant figure out what to take apart to get at it.
From the posts I can see that there were others who got at the Power supply to check the caps but they dont say how they got there.
techman has the answer to this
  • Neal Coticelli Dec 07, 2007
    The link was helpful but it was for a different model than mine.
    I have a mitsubishi wd 52522.
    If I can get at that power supply board I know that I can check the caps.
    What do I take apart to get at the boards (power supply?
    Problem Solver:
  • 6 Answers
Hey dude if your prob is solved its good but if not then try this out
or this may answer your question
need other help plz do not hasitate
Posted on Dec 07, 2007
  • 4,402 Answers
I think this is what your referring to
  • Cary Farah
    Cary Farah Dec 08, 2007
    at the site there is documents (zip file) of how to get at the parts and how to get at them.
Problem concerns Samsung HL-S5087W. All of a sudden, TV goes through 3 startup cycles and shuts down resulting in 3 blinking lights on front panel. What I've done: Completely cleaned inside of...
3 blinking led light at the front panel is an error code for lamp malfunction. If you've already replaced the bulb and yet the symptoms remain the same, then high chance that the fault came from the ballast board because the supply voltage is present.
Confirm if the bulb will lit upon powering on the unit. Open the lamp cover, bypass the lamp cover switch by putting tape to make it in closed position (making it still the lamp cover is attached to the housing) and then power on the unit. Check if the bulb will ignite or will light up, if not, you have to replaced the ballast board.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jul 14, 2011 | Samsung HL-R5087W 50" HDTV-Ready...
Red light lit on front panel indicating a bad lamp
It'll likely be right behind where the power cord from the TV comes from.
Dec 07, 2007 | Mitsubishi WD-52525 52" Rear Projection...
My Sanyo PLC XE31 wouldn't switch on, bulb replacemetn lamp was lit. Changed bulb and now it switches on, green light shows, fans run, and then after approx 30 seconds the red light flashes and it switches...
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Jan 24, 2011 | Sanyo FOR PLC-XE31
Panasonic PTL500U LCD HiDef projector. Unit occasionally powered up briefly, lamp lit, then shut down, standby LED flashed orange/red. Sometimes lamp lit and sometimes not. Technician diagnosed bad ballast...
If you take the back off you might find a couple of bulged electrolytic caps on the power supply board that need change, or just buy a new power supply at
Dec 22, 2010 | Televison & Video
I changed the bulb and still the two red indicator lights are lit on the front of the projector. One is power and the other is Lamp. i can not turn the projector on or off and i have plugged it in for 2...
Unfortunately, the "two red light" problem appears to be common to Sharp and Eiki projectors (some models use the same circuitry). Your projector will need the power supply and/or ballast replaced by a technician. From what I've seen, that can run several hundred dollars.
Nov 29, 2010 | SharpVision XV-Z9000 Multimedia Projector
SHARP XV-Z91E Projector Replaced lamp but
hold down menu, enter, and down arrow, then press power. this is the only way to reset the lamp timer. if it won't turn on and there are no leds lit, you may have to reset the bimetal breaker. to do so, remove the 6 bottom screws and the top 2 screws on the back panel, and remove the top case. on the front side of the lamp housing, you will see a red button. press it. if it clicks, it is reset. if it doesn't, it wasn't tripped, and you have a power supply issue.
Jan 12, 2010 | Sharp XR-10X Multimedia Projector
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
in this case you may have problem with light engine or power supply this is a job for experienced tech for more info e-mail me or call 520-248-4242
Apr 02, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
1,184 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
