Question about British Telecom Bluetooth? Headset :unitsize BT350WB Wireless Headset
Telecom BT500 head set ( not the Jabra!!)
Have a BT 500 but have lost the instruction booklet!! any one have it on eforrmat?
0 characters
1 Points
Is the rechargeable battery in the Jabra BT500 replaceable?
  • jabra headset battery swap - YouTube
    • 3 MIN
    • ADDED 2011-12-10
    Video embedded · jabra headset battery swap theDIEclan2004. Subscribe Subscribed Unsubscribe 15 15. Loading ... Plantronics Pro battery replacement - Duration: 9:15.
  • Jabra BT500 Bluetooth Headset -
    • 4/5
    • 69 REVIEWS
    Buy Jabra BT500 Bluetooth Headset with fast shipping and top-rated customer service.Once you know, you Newegg!
  • Jabra SPORT Bluetooth Battery Replacement - YouTube
    • 2 MIN
    • ADDED 2013-09-23
    Video embedded · A quick video showing the ease of replacing the battery in the Jabra Sport bluetooth headphones. Jabra says when it it out of warranty they cannot be ...
  • Jabra BT-350 Disassembly and Repair - Instructables Intro: Jabra BT-350 Disassembly and Repair. I wooted a few of these dandy devices a while back and they work great but the volume buttons are weak and the solder ...
  • Jan 26, 2016 | Jabra BT500 Wireless Headset
    What if i can't find my model phone for instruction to connect to?
    Paring the JABRA head set to Mobile phone
    1. Turn headset off. Press and hold until solid light comes on.
    2. Activate Bluetooth on your phone.
    3. Search for Bluetooth devices and select Jabra BT2070.
    4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 (4 zeros)
    Thank You
    Aug 31, 2010 | British Telecom Jabra BT8040 Wireless...
    How to set the Jaba BT500 headset in pairing mode?
    Jabra has an online tutorial on pairing.
    It can be found here:
    Choose your BT500V from the list, then choose your phone / pda model from the next menus.
    Jun 20, 2008 | Jabra BT500V Wireless Headset
    Bluetooth help
    When you pair the bluetooth headset default passkey (PIN) should be used as "0000" (4 zeros). for further info you can check the user manual as I attached the link below
    Good Luck
    Feb 20, 2008 | Jabra BT500 Wireless Headset
    Jabra bt500
    yeah charge it for 14 hours......and then hold the pair and call at the same time... then repeat the pairing process
    Jan 04, 2008 | Jabra BT500 Wireless Headset
    Can h700 pair w/multiple devices?
    Jabra JX-10 II but i'm not recommend because my friends said that this model not as good as normal JX-10( low volume, low signal, more noise, sth like that)
    Dec 28, 2007 | Motorola Mobility H700 Wireless Headset
    Jabra BT500 will not power on or charge
    I would also like to know if you find a fix for this problem. I have the BT500 and it will also not turn on.
    Sep 17, 2007 | Jabra BT500 Wireless Headset
    INstallation instruction for Jabra BT350 with a Palm 650
    Hold the button on the flat side (power button) until light stays on. It is now in discover mode. Next, set your phone to look for BT devices. The passcode is 0000. That should be it.
    Apr 23, 2007 | Jabra BT350 Wireless Headset
    Jabra BT500
    I had a very similar problem. Your headset is most likely defective. Call Jabra at and they'll replace it for you if you still have the receipt where you bought it from.
    Dec 03, 2006 | Jabra BT500 Wireless Headset
    British Telecom Bluetooth? Headset :unitsize BT350WB Wireless Headset Logo
    173 people viewed this question
    Top British Telecom Headsets Experts
    Brian Sullivan
    Brian Sullivan
    Are you a British Telecom Headset Expert? Answer questions, earn points and help others
