Question about Electrolux EL5010A Bagged Upright Vacuum
Wiring Two wires (black and red) connected to the slider on/off switch have overheated and melted away the 90degree connectors. Will replacing just the connectors solve the problem or is it more complicated, such as a resistor, capacitor, etc.?
  • Anonymous Nov 14, 2008
    I have had this problem with two of these vacuums now. I think it may be a component defect.
  • 833 Answers
This is easy and hard. If only two wires connect to the switch, cleaning up the connectors and replacing damaged items should fix it. Don't do anything unless the unit is unplugged. Try this first: connect the two wires together and tape them up. Plug in the unit. If it starts, make your repairs. If not, unplug immediately. The switch fried for a reason. Most vacuums do not use electronic components...just a standard brush style motor. If the motor is bad, it may not be worth replacing it. Let me know what the test result is and we'll further.
Posted on Dec 07, 2007
Wiring diagram
First check the cord to make sure you have continunity throw both leads, check them at the cord reel, there are 2 wires hooked up to it, if not then the cord is bad. Check the swith also, the next cause would be the speen control mounted on the motor, part #04416342, sells for around $85. If your motor checks ok, then it most likely the speed control, they go out quite often...Thank you
Regards!!!...
Jul 24, 2008 | Miele Cat & Dog 326i Bagged Canister...
I have a Kenmore Upright Model # 11630412001 with a broken power cord
Normally, you would leave the current power connections attached and then line up or label the new cord lines with the old.
There should be a common ground, easy enough to dsitinguish.
A hot, normally black.
A return, normally white.
These may be swapped it the existing wire colors are.
Red = new black
Black = new white
Green or Blue = Green or bare.
I'm a bit surprised t read your post as the cord should have come with connection instructions if the replacement cord is different in color scheme from the old.
ALWAYS TAKE SAFETY PRECAUTIONS WHEN WORKING ON HOT LIVE POWER. NEVER MAKE CONNECTION CHANGES WHILE THE VACUUM IS PLUGGED IN.
IF AFTER YOU CONNECT THE NEW LINES, TEST THIS BY TURNING ON THE VACUUM AND TURNING IT OFF RIGHT AWAY. IF YOU HAVE POPPED A BREAKER OR SEEN BURNING, YOU HAVE TO SWITCH THE BLACK AND WHITE WIRES.
The best thing is to always go online and find the wiring layout for you model.
If you have any doubt, pleast post the wire colors you do see now coming to the connection terminal and post the colors coming out of your new power cord.
Regards,
Worldvet
Jul 05, 2008 | Kenmore 35912 / 35913 Progressive Upright...
I have a 9068G and when I plug into the electrical outlet and press the "on" lever, I get nothing. The machine actually quit one time while I was vacuuming. Is there a fuse problem or a reset button? ...
There is no reset button or fuse, yo have a clog / reduced air flow, causing the motor to over heat and turn off. First change the bag, then remove the wands and carpet tool from the vacuum. See if the machine turns on. If not the main motor will need to be replaced. If it turns on and you have suction, check the wands or carpet tool for a clog.
Apr 16, 2010 | Samsung Quiet Storm 9069 Vacuum
The handle for my Eureka 5893 AVZ was getting very hot. Finally, the wires around the switch melted and the vacuum will not work. What is wrong? Is the switch bad? Nothing else appears to be wrong.
usually if a connection gets hot enough to start melting it is usually a loose connection or high current. more than likely the switch is bad if you replace it with the same type of switch and it gets hot check the motor. make sure it is clean and isn't jammed
Nov 05, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
Wiring diagram s3755 hoover
Today I shortened my hose by 4" to get around a tear problem. You can use an Ohm meter to find the right 4 wires. When looking from the top of the canister with the hose heading to your left, the wires should be:
White (furthest connector away from you)
Black - to the switch
Red
Blue
With the Red and Blue going to the speed con trol curcuit board.
Aug 05, 2009 | Hoover S3755 WindTunnel Bagless Canister...
Electrolux Model E switch wiring diagram
The black wire coming from the power cord connects to one side of the switch and the other black and the red wire go to the other side of the switch. If it turns on with the switch in the off position reverse the sides. Good luck. If you need anymore help just ask. Please rate me so I know if I helped. Thanks.
Dec 30, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Eureka Boss Smart Vac 4870 evidentally overheated. Allowed unit to cool and observed a spark/smoke at outlet when it was replugged into the power outlet. Unit will not power up now. Circuit breakers in...
The wires leading to the switch inside my Eureka 4870 are fried...black and melted. Don't know why that happened, but it may be what is happening to the others listed on this site as well.
Dec 18, 2008 | Vacuums
Eureka 5892BVZ ON/OFF switch burnt
COUNT ME IN ON A CLASS ACTION IF ANYONE KNOWS A GOOD LAWYER.
Here's my story, posted on other solutions here, especially on the Model 5893; many people with burned wiring and switches. Major fire hazard imo! Okay, here's the skinny on my upright Eureka POS vacuum:
Had a problem with my upright Eureka Model 5893 bagless kinda starting and stopping. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis). It is Part #27871.
Feb 01, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Electrolux EL5010A Bagged Upright Vacuum Logo
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
