Question about Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer
Shutting off early
I have a front loading Neptune washing machine. I bought it second-hand. The problem is that the machine will turn off before it goes to through the cycles. I have placed the switch on #2 rinse. The water came in, but after a couple of seconds, the door locked light came on, the water stopped, and the on light went out.
    Problem Solver:
  • 10 Answers
Check out http://www.maytagfrontloadsettlement.com. This sounds like the same problem many other Maytag customers have encountered (including me).
Posted on Dec 08, 2007
Keep getting Lr halts with even the lightest loads. Takes hours to do one load restarting, adjusting, restarting.
This is a common issue with earlier Maytag Neptune Front Load Washers due to a momentary loss of motor control neutral feed from the power cord and result to the shutting down of the washer in the middle of the cycle. The neutral feed line needs to be checked for poor connection. Check the tip I posted regarding this problem and how to address it.
May 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune front load washer keeps shutting off during the wash cycles. Any idea as to what is wrong and how to fix?
my matag neptune front load washer keeps shutting off durning the wash cycles,and the letters LP keep appearing.Any idea as to what is wrong and how to fix it?
May 01, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune error code lr
i think this one is the one with the clutch. if it does it b4 it spins. put it on a spin. if it doesnt spin, u need a clutch. under the unit the belt is whapped on it
Feb 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune front loader
check the following
power cord plugged into a grounded 3 prong outlet
the inicator on the cycle conrol knob proprely lined up with a cycle? turn the knob to the right slightly then pull the knob
are you using a extention cord if so dont
washer overloaded
Jul 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Draining neptune washer
The sloshing sounds you hear are supposed to be there. Actually, it was there when you first purchased the washer and had never used it before. It's part of the balance system. When the machine goes into high speed spin, the balance system kicks in. The water portion of it is forced outward by centrifugal force. Now when the machine slows down and stops, the water settles back down so that when you reach in and turn the drum by hand, you can hear it sloshing about.
Hope this helps,
SG
Mar 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Hw 2 open the washiingb mashine door?
First you must check if there is power in your wall socket, then turn on the machine, try to gently open the door (the door has a catch). If it still does not open, press the 'end of cycle' button.
Click on your model number (below FIXYA) on this website, type in & search. You will get a shortlist; click on your model, below the page you will get Manual/Guides. Click on the blue, you have your manual on line. If available that is............
Feb 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Digital control panel is blinking on my neptune front loader!
My screen blinks when the room is cold. If we warm the panel up with a heating pad, it works fine.
Jan 26, 2009 | Maytag MAH6700AWW Neptune Front-Load...
MAYTAG Mah4000 front loader washer
HAVE YOU CHECKED THE MOTOR CONTROL BOARD?IT IS LOCATED INSIDE THE FRONT RIGHT BOTTOM OF WASHER BEHIND FRONT PANEL,LET ME KNOW IF YOU FIND ANYTHING-MIKE
Nov 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer Logo
138 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
