Refrigerators Logo
Posted on Sep 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Refrigerator is toowarm . - Refrigerators
Anonymous
Level 2:
Champion:
  • Expert 239 Answers
  • Posted on Sep 03, 2009
Anonymous
Expert
Level 2:
Champion:
Answers
239
Questions
0
Helped
78828
Points
421
Defrost the freezer
Everest esr1 refrigerator
Yes, it does exist,. It is a commercial reach-in refrigerator.
ESR1 ' Everest Refrigeration
everestref.com > product > esr1
Description. Everest's Upright Top Mounted Reach-In Series offers an outstanding combination of refrigerator, freezer, and dual temperature options as well as full ...
Everest Refrigeration ESR1 29-1/4" One Section Solid Door ...
www.restaurantsupply.com > everest-refrigeration-esr1-...
The ESR1 is a 29-1/4" wide, one-section stainless steel insulated upright reach-in refrigerator from Everest Refrigeration with 1 full-size self-closing and field ... Door Style: Swing
Number of Shelves: 3US$2,176.00 · ‎In stock
Everest ESR1 29-1/4" Solid Door Upright Reach ... - Amazon.com
www.amazon.com > Everest-ESR1-Refrigerator-29-25...
Buy Everest ESR1 29-1/4" Solid Door Upright Reach-in Refrigerator, 23-Cubic Feet, NSF: Refrigerators - Amazon.com ? FREE DELIVERY possible on eligible ...
Everest Refrigeration ESR1 29" Solid Door Reach-In ...
www.therdstore.com > page > IFSES > PROD > ESR1
Shop commercial refrigeration equipment at Restaurant Depot. Commercial refrigerators, commercial freezers, merchandiser or beverage cooler for your ... US$2,175.72 · ‎In stock
tip
How to troubleshoot and, repair your RV refrigerator
if this is a gas absorption refrigerator make sure it's level while operating.
check for heat at the roof vent if no heat check heating element or, gas burner behind the refrigerator accessible through the refrigerator outside hatch; next: check the relay and, inverter it is located under the refrigerator front if all these things check ok and, especially if you find a yellow power on the gas refrigeration unit the tanks behind the refrigerator box; you must replace the gas refrigeration unit by: removing the refrigerator from the cabinet from the front then lay it down and remove the gas refrigeration unit replace it with a new one but, don't forget to remove the 3' long spiral metal strip from the old gas refrigeration unit exhaust vent and, reinstall it in the new gas refrigeration unit the gas refrigeration units can be purchased online.
on Jul 17, 2010 • Refrigerators
tip
What a refrigerant mean
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Understanding Refrigerants
Before I start up my topic I will like to explain what the word refrigerant means and other things that I fill you have to know more on the subject matter.
What are refrigerants? Refrigerants are fluids that absorb heat at low temperatures and rejects heat at higher temperatures. The principles of refrigerant allow for heat pumps and straight air conditioners to function properly; because of their pressure temperature relationship. This relationship allows for heat transfer.
In the HVAC industry refrigerants are given a trade name known as "R" names. Examples of these names are R22, R134a, and R502. These names help to describe the different types of refrigerants. Refrigerants have various chemical make ups, along with different properties. Some refrigerants are only able to work in high pressures while others use low pressures to function properly.
There are three main make ups of refrigerants that are currently used. Hydrogenated Fluorocarbon Refrigerants (HFCs), which is made up of hydrogen, fluorine, and carbon. Because they do not use a chlorine atom (which is used in most refrigerants) they are known to be one of the least damaging to our ozone. Hydrogenated Chlorofluorocarbon Refrigerants (HCFCs), which are made up of hydrogen, chlorine, fluorine, and carbon. These refrigerants contain minimal amounts of chlorine; they are not as detrimental to the environment as some other refrigerants. Chlorofluorocarbon Refrigerants (CFCs), which contain chlorine, fluorine and carbon. These refrigerants carry high amounts of chlorine so they are known for being the most hazardous to the ozone layer.
Sometimes refrigerants consist of a two or more chemical compounds. These blends break down into two types: Zoetrope’s and Azeotropes. Zeotrope A zeotrope is a liquid mixture that obeys Raoult's law. It shows no maximum or minimum when vapour pressure is plotted against the composition at a constant temperature.Zeotrope refrigerant mixes are mainly made of three different types of refrigerants. The characteristic that describes this type of refrigerant is that all three refrigerants keep their own properties; they act as 3 individual refrigerants. Azeotropes are mainly a blend of two refrigerants. The property that defines this type of refrigerant is it acts as a single refrigerant. This effect the boiling points of both types of refrigerants.
The most important fundamentals of refrigerants before expanding into how they work. This key principle is that refrigerants do not make things 'cold' they remove heat. This principle is preached in the HVAC industry. It is a common misunderstanding of homeowners and technicians.
A pressure temperature relationship is a way of describing the specific temperature that relates directly with the pressure of a substance. This allows control of refrigerants boiling temperatures. Controlling a refrigerants boiling temperature allows for proper heat transfer.
Heat transfer is when heat from one place is transferred to another place, this is also referred to as a refrigerant cycle. Generally we control heat transfer through air, water and refrigerants.
This type of heat transfer happens through conduction. Conduction is when heated molecules, with lots of movement, collide with slow moving molecules. The warmer molecules, fast moving, always move towards the cooler ones, or the slow moving molecules.
Refrigerants are sold in disposable container that includes a check valve. This limits the reuse of old refrigerants and prevents mixing refrigerants. Refrigerants are identified by a standard color code. The labels also contain information on which type of refrigerant is in the container along with any safety hazards there are.
There are several safety hazards when handling refrigerants. In order to help prevent damage to the ozone, technicians are required by law to become EPA certified. There are four (4) main types of certification; Type I, Type II, Type III, and UNIVERSAL. Type I includes small appliances such as refrigerators. Type II includes high pressure appliance with the exclusion of small appliances such as split-systems. Type III includes low pressure systems such as chillers. A Universal certification includes all three types of certifications. For more information on refrigerants, their properties, how they effect the environment, and becoming certified.
on Feb 26, 2010 • Refrigerators
Refrigerator motor is runnung but both thr frezzer and refrigerator is not cold
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
The freezer works fine, refrigerator section not cooling it is 6 yrs. old, should it need a refrigerant(freon) charge ?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
2answers
Refrigerator cold ice on ceiling no air to refrigerator and its warm the fan not turning
Refrigerator Repair is difficult over the internet but that is a bad sign and frost build-up usually means that your compressor has gone out in your refrigerator.
-Fred
www.ezfixappliancerepairlasvegas.com
Refrigerator is not sufficiently cold. Changing
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
JCD2389G Side by Side Refrigerator: REFRIGERATOR SIDE OF SIDE BY SIDE REFRIGERATOR NOT...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
1helpful
HOW DO REFILL FREON IN IT
Is your entire refrigerator not cooling?
Refrigerant service must be performed by a certified refrigerant specialist. Are you certain that you need refrigerant? If refrigerant is required, then you have a leak. Normally, refrigerant should last for many years without requiring new refrigerant (sealed refrigeration system). Your problem may be attributed to one of the following:
* compressor
* components attached to compressor: relay, capacitor (if applicable) and/or overload protector
Contact an appliance service company.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
