Question about Lexmark X4270 All-In-One InkJet Printer
COLOR QUALITY Pictures come out too red! Everyone looks like they are sun burned.
  • 42 Answers
Goto control panel, look in printer"properties" select "color managment" set color profiles to automatic, if this doesn't work run nozzle cleaning in printer maintenence.
Posted on Dec 09, 2007
WD-60638 DLP TV does not have any red
It would have come with a 1 year labor and parts warranty--now is the time to see to the issue---Talk to Mitsubishi if you do not have a extended warranty that is active.
Nov 03, 2012 | Mitsubishi Televison & Video
When i take a picture with the flash, it has a yellow tint to it. Why?
Most likely your white balance setting needs to be adjusted. You didn't specify the model of your camera, so I can't tell you exactly how to change it (your manual should say).
Your camera should have several settings:
"A" or "Auto"
"Daylight/Sun"
"Tungsten" or "Indoors" or "Incandescent"
"Fluorescent"
and possibly also:
"Flash"
"Cloudy" or "Shade"
When taking flash pictures, the "Flash" setting should be best. If you don't have a flash setting, then "Daylight" or "Sun" will be the best.
Human eyes adjust quickly and easily to different colors of light, but cameras see light as it is, so indoor light will look yellow, outside bluish, fluorescent greenish, etc. So digital cameras shift the colors in the image to try to make white objects appear white like they would to your eye. But sometimes they mess up and don't get it quite right. That is where the manual white balance settings come in. If you play with these settings, then you will find you can improve the color quality of many of your pictures.
Dec 03, 2010 | Cameras
53 inch projection tv...seems like the color red and color blue have shifted giving me a picture with red and blue shadows
For CRT projection TV's, this indicates that the Green picture tube is burned (warn out). The less green that strikes the screen, the more redish the image will look. You will need to find an old school TV repair shop that knows how to replace picture tubes.
In the case of a DLP style TV, the color wheel needs replacing.
Dec 29, 2009 | Hitachi Televison & Video
TAKING NIGHT SUNSET PICTURES
this is becouse your not setting the "white balance"
up in the camera first,,,some digital cameras have a manual set up for "white balance" what the camera is doing is trying to put the color cast thats in a sun set right so it looks like day light,,,and you wont that color cast in the pitcher to give it that feeling,,,unless you over ride this white balance you will never get the color you are after,,, i use 35 mm film for sun sets
it will wip a digital camera every time here,,
but its horses for corses,good luck with your sun sets,,, but over ride that white balance first if you can
Nov 16, 2009 | Kodak EasyShare Z712 Digital Camera
Small red dot in center of 53" Hitachi projection tv
hi, not good news it`s probably a burn in on your red crt (picture tube), tv has to have back completely removed, which means top and bottom covers, (carefull with the top cover it`s heavier than u think, has mirror bolted to inside), turn on tv just long enough to light up all 3 crt`s to identify the red one, turn set off & look into red lens,(may need flashlight) if you see any black specks in center of tube it`s burnt and has to be replaced, be advised u will see gnats, ect. inside but your looking for specific speck, if no visible burn mark have tv man come out, otherwise it`s very pricey, hope this helps and not crt, video-tek
Jun 06, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Vizio 42" fhdtv - need help for better picture quality settings
Since you're using "analog cable", I would adjust the television such that the picture is not streched. This means there will be black bars to the left/right of the 4:3 picture, but you should experience some improvement in picture quality because the TV is not trying to interpolate what to do with an already crappy analog cable signal.
You may also want to add a signal booster where the cable first enters your residence... often, folks split that analog signal up so much it is weak... and looks much like you describe.
Mar 09, 2009 | Vizio VW42LF 42 in. LCD HDTV
Poor picture quality
The problem is probably the convergence power supply.The switching power supply chip on the convergence board will burn out, producing a rounded picture with 3 separate colors. The chip is a long, heat-sinked SIP (single-in-line package) located on the convergence board. You can find replacements on ebay.
Apr 03, 2008 | RCA P61927 61" Rear Projection Television
Poor color
What kind of cables are you using? I had poor picture quality until I upgraded to HDMI, the picture's great now.
Dec 16, 2007 | Hitachi P42H401 42 in. Plasma HDTV
Color distortion issues
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Oct 07, 2007 | Sony Grand WEGA KDP-65WS550 65" Rear...
Pictures printing with stripes of color in some programs but not all programs.
Try new injet cartidges. If your printer has separate head and ink combo, replace the jets. The high quality mode operates the piezo jets at full power and lower setting can cause jets not to open as far. On some preinters, your particalar problem can be the result of too thin paper and the economy setting being used. Use 18lb or 20lb paper and see if it still does it on normal print mode.
Apr 27, 2007 | Canon MultiPASS MP730 All-In-One InkJet...
Lexmark X4270 All-In-One InkJet Printer Logo
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
