Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Partial thawing Things on the top shelf are thawing. The ice maker which is right below it is stillmaking ice. Things on the lower shelfs are fine if they are in the back of the freezer. I also think that it is running non stop. When I lower the temp it does not kick off.
  • Anonymous Mar 27, 2014
    not cooling, freezer only on the lower shelf.
  • 23 Answers
Make sure that vents aren't obsturcted, you need to have airflow, second make sure the coils either on back side or underneath don't have alot of dirt on the fins. Make sure your door seals are tight all around, take a dollar bill and in different spots around the seal close the door and pull on it. If it comes out to easy then the seal is no good or a door adjustment is in the works. Worse case scenario is the compressor is low on refrigeration or no good. Check the easy things first and let us know thanks.
Posted on Dec 07, 2007
Will not dispence water
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Layer of ice formed on the bottom of freezer and a layer of water with no obvious source has formed on the top shelf on the right side.
That is an easy one. Instead of the defrost liquid draining down the drain hole it is blocked and a slab of ice is forming. You must thaw out the ice box and clear the drain hole. Another thing that could cause this slab of ice could be a leaky ice maker water valve or a faulty ice maker pumping in too much liquid into the ice mold.
Jan 15, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice melts in freezer
check your inner box liner for cracks also your door seal's you have a air leak
Jan 13, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Ice maker quit after my husband over filled the top shelf and blocked the air flow for the freezer. The freezer started to defrost itself and water was on the floor in front of the freezer. He unblocked...
Yes, If you will try a couple things. Fill ice maker with water and let freeze. Tell me if it will drop the ice when frozen, Let me know that and your model number. I am doing this to decide which one is the problem. The ice maker or the water control valve. Sea Breeze
Nov 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kitchenaid ice maker dripping and freezing down freezer shelfs
Tube sometimes freezes because of minerals in it hold one droplet at a time until buildup freezes solid. Replace tube first. Water valve allowing some droplets through can also cause this. Tube first-less expensive.
Aug 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Bottom of freezeer and fridge are cold, but top areas aren't?
you have defrost problem or check see if condenser fan working
Apr 07, 2009 | GE Refrigerators
Kenmore refrig not making ice and top shelf area in refrig not cold
if you are having tempurature issues make sure the fan in the freezer is operating. it should be on when the compresor is running. this may explain both warm fridge and no ice.
Sep 10, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
