Question about Forfex FX 766 Hair Trimmer
Forfex trimmer FX766 won't charge
I am not sure why my trimmer won't charge. One day it  was fine and I do keep it plugged in all of the time because I use it frequently, yet now the light is on as if charging yet the unit is dead. I know the blades are good and well cleaned. Does the unit need a new battery ? I can't figure out how to open this. Also, could it be the charger? I cleaned the connection points to make sure the charge was getting connected and changed wall outlets. Any ideas or who I can have repair this in So. Cal. ? I hate to have to buy another. Thanks, angelhair
  • aminscho Oct 06, 2008
    I also have forfex trimmers and it just stoped working. Where can I get them repaired in the Charlotte, NC area.
  • Ann Crosby May 27, 2012
    SorryJulie, it was new at that time & the batteries are not replaceable. Thanks anyhow. It is a problem they had with the way they made the contacts, They have since changed them on this model.
  • 4 Answers
Angehair,
It is most likely the battery, don't even try to open the case if you don't know what you are doing, Forfex will not replace the batteries in these small trimmers as they state it is too labor intensive, I am working on obtaining batteries for these units.
They have to be soldered in.
Posted on Feb 04, 2008
The charger base contacts brake luse and no longer makes good contact with rhe clippers.
Posted on Nov 15, 2008
  • 4 Answers
If there is just no charge after you plug in for awhile, my guess is you need to get a new battery for it
Posted on May 26, 2012
Battery won t hold charge
If your battery does not hold charge, and you don't want to buy a replacement, then there is not much can do other than to keep using your laptop with the charger. All batteries have a time life span.
Jun 19, 2013 | Acer Computers & Internet
Craftsman tiller won't start unless I manually prime cylinder with gas. There is no primer bulb. Can I retrofit a primer bulb in the gas line?
Hi
You can insert a primer system into your fuel system
Just follow the fuel flow below
Please take time to rate me
Bud
Oct 23, 2012 | Craftsman Garden
Have a new craftsman edger, 27cc 2 cycle. Have used one time. Worked fine. Now trying to use again and won't keep going when cranked.
If it worked the first time you used it, what changed since then? It sounds like you have old, dirty or water in the fuel. Is this possible? I need a few more details on how it acts to help you.
Jim
Aug 07, 2011 | Craftsman 25cc Gas Line Trimmer
Do you have to keep it plugged in the whole time? Or does it charge up?
Yes you have to have it plugged i.It is an electric trimmer,but not battery operated.
Aug 01, 2011 | Black & Decker 14" Grass Hog Xp...
My worx will not stay charged... the charger goes green after about 10 minutes and only runs for about 5 minutes...
it sounds like the battery has seen better days. a battery will get a "memory" and after while it could fully charged as far as the charger know but only hold a little charge. with the advices in batteries they shouldn't do this but they all do wear out of time. I would get a new battery, and everything should be just fine. With the any new rechargeable battery you want to make sure that you charge it completely and drain it the whole way before recharging.
Best of luck
Mark
Jun 23, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
How long should trimmer run on a charge.
How large is your yard? On a small yard (like a townhouse front & back yard) the trimmer should last long enough to do the yard a couple of times before needing to be recharged, but it depends on the individual yard, how many weeds you have, and whether you keep it running a long time.
If the trimmer charges at all but not for a very long time, it's either the charger or the battery. Check the charger when it's charging to make sure the red light stays on -- if it goes off or blinks, you need a new charger. If the charger light stays on but the battery doesn't hold a charge, you need a new battery.
Hope that helps!
Jul 16, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
Problem choosing the correct string for my weedeater
When you go to purchase the line and are not sure what diameter to use buy the smaller size. It will work fine,but may need to be replaced more frequently. Most importantly you'll reduce the risk of damaging the trimmer.
Apr 07, 2010 | Garden
Won't start
drain fuel tank. keep depressing the primer bulb until it is clear. drain tank again. remove carb cover and disconnect lines one at a time. keep depressing primer bulb to get rid of excess gas. remove spark plug an turn engine in a position that the spark plug inlet is facing the floor, pull starter rope a few times to get rid of gas in the engine chamber.
Oct 22, 2009 | Homelite Mighty Lite Lawn Trimmer
Forfex FX 766 Hair Trimmer Logo
1,581 people viewed this question
Top Forfex Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Forfex Health and Beauty Expert? Answer questions, earn points and help others
