Question about Lexmark C510 Laser Printer
CODE 38 mEMORY FULL
PRINTER WILL NOT WORK
A laser prints a whole page at a time, some pictures or pdf's require more memory than is installed on a original machine, you can buy additional memory modules to install on your printer which will allow you to print the entire document. I bought two 1 meg modules for about $50 each and have not had a problem since. Check your user manual or the lexmark web site to make sure that you are getting the right memory. The lexmark memory is about half the size of normal computer memory.
Posted on Dec 27, 2007
Lexmark Optra S1250 Printer - Message "38 Memory Full". I tried to power on the printer without the printer cable attached.
You may have a document (or multiple copies of the same document ) stuck in the print queue. Turn off your printer, then pull the plug. Got to the control panel (or equivalent) on your computer and check the Lexmark print status for content and delete it, if possible. Reconnect the data cable to the printer, then reconnect power and turn it on to initialize. Cue up the print job again and go.
Feb 16, 2018 | Lexmark Office Equipment & Supplies
How do you clear the fax memory on a OCE FX3000? Says memory is full. Not connected to a pc just use machine for copies and fax
Check your owners manual. your machine may be out of memory. To free up extra memory, you can turn off
fax storage (see Turning off Remote Fax Options on page 64), print fax messages
in memory (see Printing a fax from the memory on page 46) or cancel a delayed
fax or polling job (see Checking and canceling waiting jobs on page 38)
Sep 14, 2016 | Office Equipment & Supplies
My printer is showing a code c-38-51 and will not work
Hi, C-3851 is related to the fusing unit. Specifically, the lower roller is at an abnormally low temperature. Unfortunately you cannot reset the code in a normal manner. Konica Minolta, for health and safety reasons, make fuser related codes engineer resetable only.
I'd rather not post the procedure here, so drop me a private email and I will advise on the procedure.
Regards
Tam
Mar 20, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Error 409 Memory full on Monarch 9850 printer
409 is a memory full error, so if you have reset the printer, then your memory should be "flushed". You may also have an incorrect flow control, so when you send too much data to the printer, you can get a 409.
Not knowing which your issue could be, try calling the company's support number 1-800-543-6650.
Mar 19, 2009 | Monarch 9850 TABLETOP PRINTER
Need new codes for eurovox telewest
hey try this code
5A 01
AA B7 D1 D9 CE 8E 83 AF
A1 38 06 29 24 29 8D 2B
it works on mine
goodluck
Jan 18, 2009 | StarTech.com StarView SV211K 2-port KVM...
Eurovox codes
new codes for 5a 01 north east
e7 d3 69 2e 6f 38 ea 78
a1 38 06 29 24 29 8d 2b
recoded mine @1800 29/01/09
happy viewing.
Dec 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
Incompatible cartridges
I don't have an MP145 but from what I know that printer uses the 830/831 and 40/41 canon cartridges. I'm not familiar w/ the 37/38 as we don't have it here but from the pictures that I've seen they look identical. Unfortunately, Canon may have done some region coding like HP as I've only seen the 37/38 in the European websites. You can try it but I would suggest you changed it to the 40/41. Also if you have the original box of the printer, it should indicate there what cartridges are compatibe. If the 37/38 is not written on it then its not compatible. Hope this helps.
Nov 15, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Error message: 38 memory full
you may have some corruption on the power point .
try printing only one page at a time.
if it refuses to print a certain page you have found the issue.
Feb 29, 2008 | Lexmark C510n Laser Printer
Lexmark C510 Laser Printer Logo
777 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
