If it makes the switch when plugged into AC ok and just not on the generator then there is something coming from the generator interfering with the control. If it will not switch over even on regular AC then the relay board is malfunctioning. You can try tapping on the relay to see if it is stuck. Eric
Was this helpful?
Yes
No
Popular Solutions for Dometic NDR 1292 Refrigerator
Works fine when on gen but refrig does not cool when plugged into shore power...freezer works....
(More)
Works fine when on gen but refrig does not cool when plugged into shore power...freezer works. Driving me crazy trying to solve this. When plugged into shore, I can switch to gas but still will not work. Works great with generator. Freezer always works.
dometic ice maker will not fill with water. the motor is working and shoot off arm raises and...
(More)
dometic ice maker will not fill with water. the motor is working and shoot off arm raises and lowersm as though it was puting out ice but warter valuve dose not open to fill the ice maker. there is water to the valave. i do not know how to check anything else out. Help Thanks tommy
Does the propane alarm have anything to do with the operation of the refrigerator? I disconnected...
(More)
Does the propane alarm have anything to do with the operation of the refrigerator? I disconnected the alarm and now the refrigerator is not working.
I've had 2 tech's look at our ice maker and the last one installed a new ice maker and solenoid....
(More)
I've had 2 tech's look at our ice maker and the last one installed a new ice maker and solenoid. Still no ice! The first tech pulled a bunch of wires and I'm thinking he did not put them back on in the right places. I have the standard Dometic schematics for our NDR 1292 but cannot find any wiring diagram for the ice maker. Specifically I need the wiring diagram for the ice maker to make sure it is wired correctly
when fridg comes on a fan comes on with a clicking sound coming from the fan. How do you get to the...
(More)
when fridg comes on a fan comes on with a clicking sound coming from the fan. How do you get to the fan
