there is a long green area on one side and a long pink area on other side of screen, not on all programmes though, this has only happened since we installed a humax freesat box, any ideas ?
The thin red, green, or yellow/brown line you see running through your LCD is a line of dead pixels. To fix this problem, you will have to get your monitor serviced or, if the monitor is new, replaced.
I have a Panasonic PT-52LCX65-K and we change the lamp two times and we have a brand new one in it...
(More)
I have a Panasonic PT-52LCX65-K and we change the lamp two times and we have a brand new one in it but the TV won't turn on everytime. Sometime the TV wont turn on,but when it's turn on everything is OK until we close it and try to open it again. The panasonic store change the lamp for us but we still have the intermittent problem. A friend tell us to change the ballast (LSEB3163A), but is this the fix? How can we test this part, because the part is expensive?
i have panasonic pt52lcx65 it kept saying to replace bulb now the screen wont come on does that...
(More)
i have panasonic pt52lcx65 it kept saying to replace bulb now the screen wont come on does that mean the bulb went complety out?
I Have green squiggle lines that are moving around on the screen. I can minimize the lines by...
(More)
I Have green squiggle lines that are moving around on the screen. I can minimize the lines by darkening the picture and toning down the color which makes the picture too dark. Any idea what is causing this and how can it be corrected. Panasonic PT-52LCX65 44 in. HDTV.
How to get rid of Green spot on 44" rear projection tv. I would also like to know why my bulb...
(More)
How to get rid of Green spot on 44" rear projection tv. I would also like to know why my bulb timer will not reset even after I followed the proper procedures.
