Question about Electronics - Others
My computer does not recognize my 1GB memory stick whn I connect to the USB port. What can gone wrong? Thanks.
  • 2 more comments
  • rubinp Dec 07, 2007
    The light comes on for a few seconds, then it goes off. I have tried severl computers but the result is the same.
    Thanks, Rubin
  • tjmatuba Nov 24, 2008
    my flash just light but i cannot see it on the computer.the computer does not read it
  • Anonymous Jan 30, 2009
    i got a memory card off a friend who had 3 and when i plug it onto my computer it dose not do anything and when i go on the removable disk it said is has not been inserted.
  • Anonymous Apr 14, 2009
    My 16MB memory stick does not work in my lap top
    Sergeant:
    Champion:
  • 270 Answers
Some flah drives need drivers . i think u r not using xp . the drivers can be downlaoded from the companys websit . can u ane the comapny
Posted on Dec 07, 2007
  • 47 Answers
Depends which operating system you have,
here are a couple of things you can do if you on windows, does the light on the USB drive come up? Try another USB port, you may be able to need to format.. if thats the case let me know and i will help you through it.
u may want to try the pen drive on another computer to see if it works.
Hope it helps
Z33m
  • Zim Taylor Dec 10, 2007
    Hey mate, like the guy said before u may need drivers for it to work.
    On the other hand i pretty sure one of the computers you have tried must be windows XP, so it may be a problem with the memory stick itself.
    please can u confirm which operating systems you have tried.
How do I connect the Irulu keyboard to my tablet, besides by plugging the mini usb into the port on the side? Because my tablet doesn't recognize, that it is even plugged in.
first of all, make sure that your tablet has an On the go USB port or data port if not, it can only be used to charge. If you connect our tablet to a computer usb port, and your computer recognises it, then you have a data port.
If you plug in a usb memory stick, and your computer can not read it, it does not have a USB to go port.
Also, some Cable adapters are On the Go wired, and may not work properly.
It may also be that the USB port is not providing enough power from the tablet to the keyboard. In that case, buy a split power usb cable, and plug the red (power only) into a usb charger or powered usb hub.
Apr 20, 2016 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
My computer stopped recognizing my Nikon and won't
Having gone a month with no further response, I assume this is no longer a problem.
May 14, 2010 | Nikon COOLPIX P90 Digital Camera
Compaq Presario S5200NX will not recognize memory stick
is either you reload the computer system or u buy an internal or external usb card.or check the connection cable inside the computer machine if it is properly connected
Jan 16, 2010 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
I have a sony memory stick pro duo 1gb and its not reading...it shows the memory card reader and then i put in the memory stick with the adaptor but is says that it has no card in it
i have Few suggestions....
Try connecting to different port on the same system, and see if it is connecting.,
if not working, try in some other system to isolate the issue., just to check whether the problem is with the system or the memory stick...
Oct 01, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Sony memory stick pro 128mb has docs on it I need. when i plug it in to laptop, it either doesn't register or says USB device not recognised. help!!!
I'm assuming the docs are important. What I would try to do is buy an external reader which cnnects via USB and hope that it is the port on the computer that is not working.
Sony MRW62E/S1/181: an external memory card reader/writer that can address 17 different memory card formats. It sports a Hi-Speed USB 2.0 interface and draws its power directly from the USB connection. The MRW62E/S1/181 can be connected to both Macintosh and Windows computers. Cost is around $30.
Sep 02, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Need pictures off memory card
More than likely this is not a memory stick problem, but a computer problem. Have you used this port before for other uses? sometime a port will get sloppy( for lack of a better word) and you may have to tilt or hold the card with your hand, so that the computer will pick it up. Try that.
Hooe it helps.
Mar 05, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Transfer music from computer to lexar 1gb
You just need to connect the Lexar 1Hb to the USB port on your computer and let the computer recognize it and then after that double click Mycomputer and you should see there the Lexar , just double click on it and now you can copy and paste music from your computer to the Lexar...
Jan 02, 2009 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Problem with USB Flash
It is possible the memory stick is faulty. Are you using xp or vista? If so it should be recognised instantly. I bought one the same a couple of weeks ago, and it recognised it instantly, and I'm using xp.
Try it on another computer if possible, even where you purchased it. Just tell them you think it's faulty. If it works on that computer then you have a problem with either your usb ports or you have a virus.
Jan 01, 2008 | Electronics - Others
Psp
* Make sure you have inserted a memory stick, and enable the usb connection via settings=>usb connection
* Check the usb cable, or simply find another one to try if it works.
* If there is a memory stick inside the psp and the psp can recognize it, then you most probably have a problem with your cable or usb port.
* if there is a memory stick inside the psp and the psp cannot recognize it, as well as the computer, then you are most likely to have a failure with your memory card.
There are too many possibilities, maybe you can give me details straightaway, so more people can help you.
Dec 26, 2007 | Sony PlayStation Portable (PSP) Console
Electronics - Others Logo
2,325 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
