Question about E-Machines eMachines Monitor E15T4
Emachine monitor My new emachine monitor suddenly looks like an hourglass I have tried the controls ( pincushion) it does not do any thing. any suggestions
    Sniper:
  • 51 Answers
You need to reexamine your display controls ...look for the icon that resembles the hour glass and then attempt adjustment
Posted on Dec 07, 2007
Emachines monitor flashes off and on
I suggest you change the Monitor or ecv.host,exe missing.
Jan 23, 2014 | E-Machines eMachines Desktop PC
Hello my computer screen all of a sudden re-sized to pincushion size and i went to the settings menu to try to change it but it is still the same size. how can i get rid of the pincushion size?
The problem is from the control panel,you need to do the settings from there,if does not work then try the monitor's settings,from the monitor.
Aug 30, 2010 | Computers & Internet
My monitor has a hourglass screen and not a full screen please help
Look in your monitors menu screen. You will see a setting to change that. On mine it is labeled "Pincushion", it bends the middle of the screens image to compensate for the curve of the glass
Sep 22, 2009 | HP Computers & Internet
THE PICTURE HOUR GLASSES IN SHAPE
Your symptom sounds like a damaged component in the pincushion circuit.
If your colors line up in the middle of the set and at the top but the picture is concave then you may have a faulty component in the pincushion circuit. When this circuit fails the picture will have an hourglass shape to it with black in the middle on the sides, or you will see square objects as hourglass shapes.
I would recommend that you have a local service center diagnose the set for you and give you an estimate of the repair.
I have seen this type of repair run from $250.00 - $350.00.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Jul 09, 2009 | Mitsubishi WT-42311 42" Rear Projection...
My screen doesent fit and it is hourglass shaped it is driving me nuts
The problem is called "pincushion distortion" and happens because of the way CRT monitors work. There is circuitry in the monitor to correct the display, but it's not working in your monitor. Often this is because of bad solder connections to transistors in the circuit (they get pretty hot sometimes and can cause the connections to degrade). It can also be due to failure of those parts.
If you are comfortable working with electronic soldering and want to try your own repair, open the monitor and examine the board for bad connections. Repair any that are grainy or obviously cracked. Typically the parts that need resoldering are mounted on metal heatsinks so you have a place to start looking.
I don't recommend paying a shop to repair this. New 17-inch LCD monitors are so inexpensive today that it's better just to replace the CRT one.
Apr 14, 2009 | Compaq QVision 171FS (White) 17 in.CRT...
Pincushion on emachines monitor
Something within the monitor or on the Video card. An Electronic Tech may be able to figure it out but it would be costly and likely not worth it. If you could use another monitor , just long enough to see if it is the video or monitor, that would be helpful, in so far as as Video cards usually are inexpensive to replace compaired to a whole monitor.    I took one in to be loked at and they had a $50 fee just to look at it.Needless to say I threw it away and gort another.
Mar 18, 2009 | Philips 107E61 17" CRT Monitor
Have you ever had this problem?
Sorry Ginko, but a convergence problem would have the curves down from the top and up from the bottom. The hourglass shape is a pincushion problem. This can be as simple as a bad capacitor in the pincushion circuit.
Could you please confirm the model number so I can look up the probable part?
Thanks,
Dan
Jan 08, 2009 | RCA F32632SB 32" TV
Pincushion Problems
check the cap that couple the horizontal transistor, this could be bad replace the flyback.all caps and transistors in that circuit should be cheked.good luck.
Apr 03, 2007 | Proscan PS27108 TV
Panasonic CT-32hX41 vertical picture problem (hourglass)
this product has a pincushion problem and requires servicing but unfortunatley it is what we call in the business NECO
Dec 05, 2006 | Panasonic CT-27HL14 27" TV
Generally,pincushion may be driven by a chip or IC,but pin out is normally a durable xistor. Servicer adjustments are minor for pin correction.Go to pin out circuit & measure voltages.Get back to me on your findings.
Nov 04, 2006 | RCA 32V430T 32" TV
E-Machines eMachines Monitor E15T4 Logo
106 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
