How to open Sony Vaio PCG-4G1M?
When I did unscrew 7 screws and 3 additional from under the screen there is still something holding it together from the center. Can't find the problem.
2) How to know if power needs to be changed (I suspect it blew up) and how to do that?
Got the puter from a friend who described as if something blew up. It is dusty and small, the friend had no mercy on a thing. So, I am just playing with it. But if it is possible to fix it on my own I would be most excited! :)
  • 3 more comments
  • walden Dec 08, 2007
    Thank you for the reply. However, I do need more specific directions. The problem is I can't see any more screws to unscrew. They must be hidden. But where? I have searched around in the internet and there have been comments about other Sony laptops saying Sony's are tricky to open (ie you have to push F1 and Delete and then slide to one direction etc etc). Nothing about my particular model though. :(
    Bummer! The model is VGN-TX2HP... Sorry, I took the numbers from below where the words MODEL were. But on the monitor edge is VGN-TX2HP. Feeling silly at the moment. Off I go to search how to open this VGN model... :) Any help will still be highly appreciated. :)
    The correct modelnumber made the magic - found excellent manual here:
  • J-Boy Dec 25, 2007
    I have the same model (VGN-TX2XP) with an optical drive that is not working - no (or very occassional) power and not recognised by the O/S. I need to remove it to check the power connections. Having problems getting the top of the laptop off. I've checked the manual link given but can't seem to get the main chassis top off.
  • Anonymous Mar 15, 2009
    pls help me with the chang of heatsink fan..??
I've just had this problem but managed to solve it.
Unscrew all the screws on the underneath, where the arrows indicate.
Then, to remove the screw in the centre of the laptop that's holding it all together, hold down the Escape and F1 key and you will see a small clip holing the keyboard down, put a screwdriver in there and push the clip back. Do the same for the clips behind the F5, F12 and Insert key.
Once you do that the keyboard will slide down and out and you can get to the last screw. Unscrew that and you can take off the top of the laptop.
When taking it apart you will detach the 2 ribbon cables from the motherboard. Take not of where these came from so you can put them back later.
My problem was that the HDD cable has popped out, giving me a n error on booting of 'Operating System Not Found'.
Problem now resolved.
Posted on Feb 28, 2008
  • 34 Answers
Useually you have to undo the screws on the back normally all of them. then the face plate above the keyboard then the keyboard and a few screws under the keyboard and you should be able to take the case appart.
as for the power use a multi meter to check the points on the battery to make sure that is working.
then check the points on the charger.
if they work then yes try replacing the power.
hope this helps
Posted on Dec 07, 2007
Posted on Oct 25, 2012
How to remove a hard drive from a sony vaio pcg-6n1l
Turn laptop over and remove screws from HDD compartment door.. Remove screws holding HDD in place and remove.
Nov 22, 2013 | Sony VAIO PCG-6N1L, PCG-6N2L, PCG-6N3L...
Drivers sony vaio pcg-4g1m
Hi ,
You can update your bios by going to , type in your make and mondel / bios drivers and you should be good ............good luck Roy
Oct 18, 2011 | Computers & Internet
Trying to open the back of a sony vaio pcg laptop
You have posted a laptop question in the desktop section. Laptop disassembly is not something you just jump into like a desktop. Laptop components are very small, and not made for assembly/disassembly. The connectors are conductive paint on ribbons, and if you remove them more than once or twice you can break the whole laptop and it won't work at all. What are you trying to do exactly. Anything more than a hard drive or memory change you should take to a technician.
Jan 13, 2010 | Sony Computers & Internet
I need to open my sony vaio model pcg-8f1l laptop. I need to repair the power input connector. How do I open?
Okay, on a model pcg-8f1l, most of the goodies, RAM, CPU, etc are accessible through discrete panels in the back, bit the keyboard and much of the bapanel stuff is accessed by removing the speaker perforated shroud (one small screw on the left and thebn slide the shroud to the right. This gives you access to the keyboard and at least have to the scress that keep the upper and lower halves together. The rest of the screws are sprinkled arount the rear case. Good luck a keep track of which screws go where.
Nov 25, 2009 | Computers & Internet
Open the case of a Sony VAIO PCG 6L7P
There are a couple removable panels on the bottom cover.Open them 1 at a time and your HDD should be in there.You'll need to unscrew the mounting bracket then pull the drive away from the attached end and then out.
Good or bad,please rate my post?
Feb 24, 2009 | Sony (B99860307) for VAIO PCG-K series...
No replacement battery for viao pcg-4g1m
Here is what I was able to find (copy the link)
Make sure that you have the model number of your laptop correct. Let me know if you find what you are looking for in the link.
Dec 17, 2008 | HP Pavilion zd8000 Notebook
How can I remove the hard drive from a Sony VAIO PCG-F305?
Remove the keyboard also,there's usually some more screws under the keyboard.
Oct 17, 2007 | Sony VAIO VGN-S460 Notebook
Computers & Internet Logo
13,940 people viewed this question
David Payne
David Payne
