Question about Compaq Evo D510 Minitower (Open Box) (OB4700432011) PC Desktop
The big green plastic that holds in the various hard drives etc. - how do you remove a drive?
How can I remove a hard drive from this tower, with that plastic gadget?
    Scholar:
  • 58 Answers
You have to push down the green thing and in the same time pull the hard drive. the green plastic gadget blocks the screws. So when you pull down they wil be released. Just take your time.
good luck
Posted on Dec 07, 2007
How to remove hard drive from dell tower
Open clam-shell type case by pushing buttons on rear top and rear bottom of case and pulling case open like a book. Once case is opened, you\'ll see the hard drive in the right half (as viewed from the back of the PC) Pull the power and data cable from back of the hard drive. Squeeze ends of green plastic slides and pull hard drive from enclosure.
Apr 21, 2014 | Dell Dimension 8300 PC Desktop
Replace hdd
turn off the computer and unplug from wall
open the case/tower
remove wires from hard drive
remove screws from hard drive
remove hard drive and replace with new hard drive
replace screws
replace wires
close up the case
turn on the computer
Does that help?
Dec 27, 2012 | Computers & Internet
How do I get the cd/dvd player into the slots that are blocked
The plastic front panel will have removeable plastic panels the size of the CD/DVD drive, these are held in place by clips, you can push the panel out.
You can also remove plastic front panel, it may be secured by screws or plastic clips. When you remove the plastic front panel the CD/DVD drive slot may be covered with a metal plate, you can remove this plate by bending the metal plate back and forth until it breaks away from the drive bay.
Jan 22, 2012 | XION (XON-001) ATX Mid-Tower Case
Blinking light flashes continually. The pc can not access the eternal hard drive. I have re-started the pc several times and the pc will not recognize the external hard drive. The WD External Hard Drive...
try to connect the usb port properly maybe there is a loose contact. and try to remove all the gadgets connected in the computer... only connect the external HDD
Oct 30, 2010 | Western Digital External USB 2.0 80 GB...
I HAVE A COMPUTER TOWER THAT THE HARD DRIVE NO LONGER WORKS. A CO WORKER WOULD LIKE TO HAVE THE TOWER AND PUT IN ANOTHER HARD DRIVE. MY QUESTION IS IS THERE ANY THING STORED IN THE COMPUTER OTHER THAN WHAT...
Only a hard drive can contain the data. Other storage mediums are CD, USB flash drive and cards. If your system has any of these, you will easily spot and remove them.
Turning to the hard drive, a computer can have more than one installed so be sure to remove each one before giving it to the other person. No hard drive means NO information stored so be assured.
Oct 06, 2010 | Computers & Internet
How do I get the hard drive out
1 Unplug the computer. As a safety precaution the hard drive removal should not be attempted while the computer is still plugged into the house current.
2 Pull the cover off the computer. This should be as simple as removing a few screws and sliding off the cover. If the process seems more involved that this, then consult your owner’s manual for the computer.
Locate the hard drive.The hard drive usually comes in the shape of a black-plastic rectangular box enclosed in a metal casing. It is linked to other components by a unique connecting device that is easily recognizable. This device is a long plastic ribbon-like cord that has a long interlocking and connecting device attached to it.
4 Remove the metal housing. This should be as simple as removing a few screws.
5
Disconnect the hard drive. All you have to do is pull the interlocking end of the lock ribbon cord until it coves free. This should not require an extraordinary amount of strength. It is similar to pulling an electrical cord from a wall socket.
Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvQCfJhS
  • Step 6 Unscrew anything that is still holding the hard drive in place and then pull the hard drive unit out of the computer. Now you can externally hook the hard drive to another computer to double check the data base. For this you will need an external holder, which you can purchase for $25 to $50 at your local computer store. Or you can add the hard drive unit to the inside of another computer tower.
  • Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvQ9MXYe
  • Step 5 Disconnect the hard drive. All you have to do is pull the interlocking end of the lock ribbon cord until it coves free. This should not require an extraordinary amount of strength. It is similar to pulling an electrical cord from a wall socket.
  • Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvQ5WTOQ
  • Step 4 Remove the metal housing. This should be as simple as removing a few screws.
  • Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvQ1AnQp
  • Step 3 Locate the hard drive.The hard drive usually comes in the shape of a black-plastic rectangular box enclosed in a metal casing. It is linked to other components by a unique connecting device that is easily recognizable. This device is a long plastic ribbon-like cord that has a long interlocking and connecting device attached to it.
  • Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvPuIEwv
  • Step 2 Pull the cover off the computer. This should be as simple as removing a few screws and sliding off the cover. If the process seems more involved that this, then consult your owner’s manual for the computer.
  • Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvPnVKmo
    Jun 14, 2010 | Sony VAIO PCV-V200G PC Desktop
    2000 pc tower , how to remove hard drive
    1. Remove a side panel from the computer tower. http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/rmvcvr.htm
    2. Hard drive removal: http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/drives.htm Look down to the Hard Drive section of this link and you should find some detailed instructions.
    You will probably just need a phillips screwdriver to get the job done. Maybe a pair of small pliers depending on how tight the cables are connected. The amount of finesse you use is dependent upon if you want to reuse the drive or computer.
    Dec 22, 2009 | Dell Dimension 2400 PC Desktop
    How do I remove the hard drive in a Acer Veriton M410?
    You have to remove both sides of your tower, because the HDD needs to be fixed firmly
    Nov 17, 2009 | Acer-Veriton-M410-US3800P AMD Desktop PC -...
    Seagate hard drive doa
    http://www.techeblog.com/index.php/tech-gadget/top-10-strangest-hard-drive-projects
    Oct 11, 2009 | Seagate Computers & Internet
    Compaq Evo D510 Minitower (Open Box) (OB4700432011) PC Desktop Logo
    313 people viewed this question
    Top Compaq Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Alun Cox
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
