Question about Xerox Phaser 6250DP Laser Printer
Color calibration I have a problem with the magenta is too light
    Novelist:
  • 208 Answers
You may first want to replace the magenta, but then do this.
  1. Press the Down Arrow and scroll to Troubleshooting.
  2. Press OK.
  3. Press the Down Arrow and scroll to Print Quality Problems.
  4. Press OK.
  5. Press the Down Arrow and scroll to Calibrate Colors.
  6. Press OK.
  7. Scroll to the Tutorial Page using the Down Arrow or Up Arrow key.
  8. Press OK to print this page.
Posted on Dec 07, 2007
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
May 09, 2014 | HP COLOR LASERJET CP 3505 N PRINTER
Bizhub C654e Color Copy Only show Cyan or Magenta Lines
So you have tried all the calibration tests? It sounds as if the alignment is off. If that isn't the case, you can try setting the copier back to default settings. I think in this make the reset button will be a tiny indented hole on the back.
Elisa Jed ' http://stores.abmcopier.com/canon-color-pre-owned/
Apr 13, 2014 | Office Equipment & Supplies
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
I have recently bought HP 2025dn, Magenta cartridge is not aligned. I am printing on 90gsm normal paper... help!!
If you are referring to a CPR (color plane registration) problem, where the magenta color plane is not aligned with the other color planes, you might first try forcing a color calibration. This can be done through the control panel menus by selecting System Setup-
Sep 21, 2010 | HP Laserjet Cp2025n Printer
HP2600n color printing not registering
Looks like theres a problem with the color ragistration.
I would calibrate the printer. Heres how;
  1. Go to "System Setup" on the display. Press Select.
  2. Go to "Print Quality". Press Select.
  3. Go to "Calibrate Color". Press Select.
  4. Go to "Calibrate Now''. Press Select.
  5. Press Select again to confirm Calibrate Now.
This will calibrate the printer and should eliminate the color registration problem you are having.
Nov 11, 2008 | HP Color LaserJet 2600n Printer
Skewed printing
Most probably you have to do the Color Registration Settings and the Color Calibration.
The Color Registration will fix the fuzzy printing and the Color Calibration the way how the colors looks. The Color Calibration it is done automatically after each batch of 40 or 80 pages and if you need you can do a manual Color Calibration BUT THE COLOR REGISTRATION must be done manually.
Go to Menu->Others->Service->Color Registration and print a test chart. Will print a page and you have to read the alignment of some lines Cyan Magenta Yellow Black with some numbers. Check the Advanced user guide for details. Basically you have to read the number / letters of each color where 2 lines are matching. Then you can enter those numbers into the printer for each color.
If the Cyan only is off then will be easy ...
Nov 03, 2008 | Kyocera FS-C5030N Led Printer
Magenta backgrounding
If the magenta is low the waste bin may be full and that may be causing the problem. If this is the case you need to change the toner. You can try calibrating the printer. You may have to do this 3 times in a row for it to make a difference.
Press Select-check mark button
Use arrows to go to Print Quality
Use arrows to go to Calibrate Color
Use arrows to go to Calibrate Now
Press Select to Confirm Calibrate Now
Jul 31, 2008 | HP Color LaserJet 2600n Printer
HP COLOR LASERJET 3500
Hi!
If you could possibly manage to access the machine status menu and have it print to check the drum's life, fuser life, developer, etc.. pls refer. Kindly replace the toner cartridge accordingly use the menu settings when replacing any color if needed. Please print solid image or block in each color Cyan, Magenta, Yellow and Balck. Well see if what color causing the problem. Please let me know the print result it may be; washed out or too light, too bright or black, double image, or not clean. Don't hesistate to contact me again about the result.
Best regards,
Rosener Guyano
Jan 31, 2008 | HP Color LaserJet 3500 Printer
Prints magenta line slightly off center on everything
Try a printer calibration.
If this doesn't work than comment again. I have one of these printers at work and I can do more to help tomorrow.
Oct 16, 2007 | HP Color LaserJet 2600n Printer
Xerox Phaser 6250DP Laser Printer Logo
281 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
