Question about Car Audio & Video
Pixelated picture I just bought my jensen uv8. Did the bypass code and everything works fine, except for playing dvds. The picture is pixelated and skips a little bit. It's not the dvd either because that plays fine on my laptop. Any suggestions? Thanks, Alicia
I have a PioneerAVH-5700DVD DVD AV HEADUNIT AVH5700 Car Video Player and i cannot get any picture to show on screen
Posted on Sep 13, 2008
  • 4 Answers
Jensen is not such a great brand for indash. if you have the receipt or warranty you might want to return it and get yourself a new one. I know this because when i bought my phase linear i didnt want to eject the cd and the guy told me that they come very defective sometimes
Posted on Dec 15, 2007
I can not play dvds in my jensen uv8 not even brand new un-opened dvds, how can i fix this ?
if it has a brake wire in the back of it ground that wire to the radio ground or any where that is a ground
Dec 02, 2010 | Jensen VM9510 Car DVD Player
Uv8
It is set up so that you can't you have to do some things with the wiring I believe to get around it. It is technically illegal to do that. If you have any other questions or need further assistance let me know.
Thanks,
Lee
Sep 06, 2008 | Jensen VM9510 Car DVD Player
Can't find Jensen UV10 e-brake bypass code.
Ok what you gotta do is connect the pink e-brake wire with the black wire that is already connected to the radio as the grounding.
UV10 Works 100%!!!!
Greetings from Montenegro
Jan 28, 2010 | Jensen Car Audio & Video
Everything works except the radio. It appears
If have factory amp you have to find the turn ou wre for the amp and hook it up to the amp turn on wire from the radio(bootleg way sound might cut in & out) or go to local sound shop and get a bypass for the amp
Aug 07, 2009 | Jensen's VM9312 Car DVD Player
My uv8 wont eject my disk
I suggest you disassemble the radio and take it out that way. While your in you can check on the blockage. Shouldn' t be hard. Good luck.
Jun 07, 2009 | Jensen Car Audio & Video
Jensen uv8 bypass code didn't work
no the code should work . unless jensen put a stop to the code in the newer modles.
Jan 19, 2009 | Jensen VM9510 Car DVD Player
Jensen uv8 video format
I've never had a problem playing videos on my unit, mpgs,mpeg,divx. Try ramvideos.com to download videos and burn using your burning software.
Oct 18, 2008 | Audiovox VM9512 Car DVD Player
JENSON VM9512 CODES FOR BRAKE BYPASS
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
Mar 10, 2008 | Audiovox VM9512 Car DVD Player
Phase Linear UV8
I have same problem with same uv8 but i use remote to activate am/fm then hit setup on rem.enter 543210 and a new menu came up. ( listening for the beep after each 3 is pressed ) select the hammer in upper left hand corner of screen, select brake bypass to on, then hot the X near bottom os screen. this works for me it should work for you.
Jan 11, 2008 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
434 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
