Question about Lexmark X83 All-In-One InkJet Printer
Light, Faint or Faded Copies
I have xerox workstation pe120i all in one printer
It has toner cartridge.
When I prinout a file from my PC, I get good quality printout
But, when I make copy of a paper the printout quality is very bad, I can not see the printout, it is very light.
I tried to clean the galss surface and I changed the constrast settings. But the results are same
What would you suggest me to do?
    Problem Solver:
  • 8 Answers
You will have to remove the glass and clean the mirrors on the scanner unit located under the glass. When these mirrors get covered by dust or other contaminants, the copy quality diminishes.
Posted on Jul 30, 2009
  • 148 Answers
How is the quality when you just scan a document?
Posted on Jun 27, 2008
Copies Still Faded After Changing Toner
can be the wiper blade, worn out drum, is there a black faint line down the side of the page as well?
May 30, 2012 | Ricoh Aficio Mp 4000...
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
Our school office Ricoh Aficio 1013 Copier has had multiple toner replacements and now does not make a full black copy but about half the copied page is faint or less dark. Is this a fuser problem? Also...
The partial faint copy in your case is most likely toner on the laser optics. It is NOT the fuser.
Since you are indicating a toner dusting or spillage issue into the bottom or perhaps paper tray area then this toner is also most likely on the laser optics. This blocks a portion of the laser light and results in a faded or sometimes even blank portion of the copies. Dis-assembly of a portion of the machine is going to be required to clean the laser.
It is located between the toner cartridge and the Drum/PCU unit at the bottom of the machine. So if you open the front door where the toner cartridge comes out. The laser strip glass would be below and to the right of there the toner is. Some of these still have a small metal cover/clip that you can remove and then slide the laser strip glass out and clean it then re-install.
Hope this helps. If this makes no sense or does not help then it might be a good idea to call a service company and have the machine cleaned.
Good Luck and Thank You for using Fixya.
Jun 15, 2010 | Ricoh Aficio 1013F Copier
Xerox 4118
That isnt unusual. The 8000 pages is for a page with 5 percent coverage area, or a rather short letter.
the 3600 to 4000 pages is not out of the ordinary for that machine, Although the xerox brand may work better, although not more copies, if you run pages with more than 5 percent of the page printed, that is about right.
Also there is no chip on a 4118 cartridge. The toner is monitored by a sensor and window in the middle of the cartridge. It shines light through the cartridge, and when the cartridge is empty the light actuates a light activated sensor.
it is not an efficient machine.
Dec 15, 2009 | Xerox WorkCentre M15i Laser Printer
Copier acted like it needed new toner cartridge, but when I replaced, copies are still very faded. When I adjust for darker copy, then I end up with dark shadows. This is Canon PC 921.
the 1st thing you need to determine is where the faint copies are coming from. is it copies or prints (from your PC.
if its the just the copies that are faint it is could be due to the optic section (these are the mirrors in the scan unit). if you have these cleaned with either an alcohol or ipa solvent this should bring your copy quality back to normal.
if you are having faint prints then it could be 1 of 2 things. either the transfer section (in laymen terms it pulls the toner from the drum onto the paper) has a poor connection/needs replacing. the other reason for this could be the charge unit that will be situated next to the drum. this over time will need to be serviced. be carefull with this part 1stly as the drun cant be in the light for to long and 2ndly the charge wire is a very fine and delicate wire. this can be cleaned and could get copy/print quality back to stardard, all that this needs to solve the problen is a service (clean charge wire and transfer roller or replece parts.
i hope this i more help than you need and you can get the problem sorted.
Dec 09, 2009 | Canon PC-921 Black and White Copier
Faded copies ,replaced toner cartridge, replaced waste toner container, cleaned inside printer
how long has the printer gone without maintenance? If your copies are still coming out light with new toner, it probably needs a new transfer roller or fuser or imaging unit.
Oct 05, 2009 | Samsung CLP 300 Laser Printer
Hp 2430 printer copies are faint
Try going to the printer properties and change the quality of the output.
Good luck
Dec 13, 2008 | HP LaserJet 2430 Printer
Printing is faded and too light
more important than all that nonsense is:
is it faint when you do an internal report or make a copy?
if only on copies it is the film on the underside of the glass.
if on prints and copies it is the drum.
Oct 23, 2008 | Dell 1600n All-In-One Laser Printer
Cyan Toner always prints faded.
It is the developer. All colours should be changed at the same time. This can be accessed via the right hand side of the machine, when you remove the cover. (where the output tray is)
Feb 06, 2008 | Xerox DocuColor 12 Color Copier
Print problem
Have you tried replacing the ink cartridge?
May 01, 2007 | Minolta magicolor 2200 DeskLaser Printer
Lexmark X83 All-In-One InkJet Printer Logo
171 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
