Question about Fargo Persona C25 Thermal Printer
Flip on long edge
I am trying to use api calls to update the flip on long edge property, but i can't get it to work. Has anyone tried doing this? if so does someone have the api call?
3 Suggested Answers
SOURCE: Card Flip Jam Error message
Open the left hand top cover, In between the ribbon rollers you will see a small flipper, ( small piece of metal with a wheel stuck on one end. ) Maually turn this so the grey wheel is on top and white smaller wheel on the bottom.
This ocassional gets jammed and need righting manually.
Posted on Aug 14, 2008
SOURCE: No option to duplex print Dell 3115cn
The duplexer is seperate purchase to my knowledge. If you have purchased the duplexer, you must enable it in the options tab.
Posted on Feb 11, 2010
How to prind 2 sided on dell 926 printer
Let me try again:
You may already have the answer, but just in case:
I'm guessing it's new printer to you and that you've never had a double-sided printer. If that's the case, I can't speak to your particular printer, but it should be in basically the same area.
  • Select the printer. Somewhere -- probably to the right, you should see a "Properties" button.
  • Click on the Properties button. Under one of the tabs you should see an option for "duplex" or, perhaps, "2-sided" printing. My printers have "two sided" but our networked copier at work has "duplex".
  • Simply select that option. ALSO, it will ask you along which edge you want to flip. It's simple with my Brother (home) and HP (work), but the flip-along-x-edge is unclear on the network copier/printer I have to use... so you might have to try it to see which one is the one you want.
    (for my personal printers, it's "flip along long edge" or "flip on short edge"... can't remember what it is with the network.
Hope this helps you... or someone else, perhaps!
Mar 31, 2014 | Dell 926 All-In-One InkJet Printer
In the past I was able to choose the Manual Option which allowed me to print on both sides. Now every time I choose this option, it goes to Off. Can you please help me with this problem?
Many printers support duplex printing, but they don't all make the duplex option available in the same way. With some desktop printers, choosing duplex means that the printer prints all of the copies of the first side of a page, then pauses and asks you to flip the sheets that it just printed and return them to the printer, after which it prints all of the copies of the second side. This method is called manual duplexing.
To print on both sides of a sheet of paper:
  1. On the File menu, click Print.
  2. In the Print dialog box, in the Name list, select the printer that you want to use.
  3. Click Properties.
Note The information in the Properties dialog box varies depending upon the manufacturer of the printer you're using. With some printers, you will see a Layout tab with a Print on both sides option on it. With other printers, you might see a Features tab, and the duplex option might be called something like Two-sided printing. Explore the various tabs in the Properties dialog box until you locate the duplex printing option.
  1. Choose the duplex printing option that you want.
The options will be called something like Long edge (or Flip on long edge) and Short edge (or Flip on short edge). Whether it's better for the paper to be flipped on the short edge or the long edge depends upon the type of publication you're printing. You might need to print a test publication or two to discover which option works best.
  1. Click OK to close the Properties dialog box, and then click OK again to close the Print dialog box and print your publication.
Sep 25, 2010 | HP Deskjet 2460 InkJet Printer
How do I print on both sides of the sheet?
If you print to an IS networked printer the printer will automatically print on both sides of the paper (duplex). This saves paper but, because it is print toner which is the largest part of the cost, charges are the same as printing on two sheets of paper.
If you wish to print duplex to another printer (NB not all printers support duplex printing) you must:
Office 2007
  • Open your Office Document
  • Click on the Office button in the top left corner of the screen officebutton.gif
  • Click Print and select one of the printers that will perform duplex printing
  • Click on the Properties button under the Layout tab
  • Choose either Flip on Long Edge or Flip on Short Edge and click on OK If your page is set up as Portrait
  • Choose Long Edge If your page is set up as Landscape
  • Choose Short Edge . Click on OK again to send your work to the printer
Other Applications
  • Go to File and Print
  • Select one of the printers that will perform duplex printing
  • Choose Long Edge if your page is set up as Landscape
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 02, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
When I try to record, I am told that my Flip camcorder is full. When i try to view the videos existing on the camcorder, I am told the camcorder is empty! I can't record, and I can't view any videos.
Try this.
Connect to your PC.
Go to MY COMPUTER.
Right click on the Flip Video Drive
Select PROPERTIES from the pop up menu.
Press the DISK CLEANUP button
When the Disk Cleanup window appears press OK
Sep 27, 2009 | Flip Video MinoHD 4 GB Camcorder
Flip Ultra HD and Mac Os X -- version 10.5 Problems installing FlipShare Help! When I try to install Flip for Mac, it freezes in mid-installation, and never closes. It does install a Flipshare...
I had the same issue with my new ultra hd and my 2008 imac. Basically, I just downloaded flipshare from pure digital's website and all is good. Another problem I have run into is that when I first plug the camera in, it asks if I want to update the cameras software, when I click 'yes', it gives the error, "unable to update camera software."
Last but least, Imovie 08 gives an error when I try to import the movies. No biggie, I just double click on the "dcim" folder in the flip video folder of the camera and I can drag the videos to my desktop, then into Imovie.
So far, not the seamless experience I was expecting, as this unit is supposed to be 100% compatible with mac's.
Steve
Sep 11, 2009 | Pure Digital Flip Video Ultra Camcorder
Hl-4070cdw prints booklets with upside down pages
I had the same problem and finally figured it out.
When you select print and the print window comes up:
select Printing Preferences or Properties (depends on program you are using),
select the Advance tab,
select the icon that has 'A' and 'B' on two pages (near the top left),
select Booklet Printing. (then Okay and Okay/Print, depends on program)
In all honesty, I'm can't remember if this is what I selected to fix the problem, but the choice is on this page. Try this with each choice of "Flip on Left Edge" and then "Flip on Right Edge".
If neither works, unselect Booklet Printing and try "Flip on Top Edge" and if that doesn't work, try "Flip on Bottom Edge". Etc.
I know the solution is on this screen so experiment until you find it.
Good Luck!
Jul 26, 2009 | Brother HL-4070CDW Printer
Flip Video Won't Turn On
For the Flip Ultra - Take out batteries you should see a flat somewhat square piece of metal with a small black piece sticking up from it. Take a pencil and push the black piece down wait a few minutes then try turning your flip back on.
Feb 06, 2009 | Pure Digital Flip Video Ultra Camcorder
Duplex Printer prints one side upside down
If it's the same as the Brother 4070 you go into printer proerties (press properties next to printer selector after sending a document to print).  Choose the advanced tab, on this tab near the top are five buttons with icons on, the second one shows two pages with A and B on, press this to access the duplex and binding options.  In there change from "flip on top edge" to "flip on left edge"
Jan 17, 2009 | Brother HL 5250DN Laser Printer
Flip share video application unexpectedly quits
Solved - I had the same problem.
The original "Flip Video For PC" software that came preinstalled on my Flip worked fine. But after being nagged to "upgrade" to FlipShare, I experienced the same crash problem mentioned here. Even worse, the FlipShare installation nuked the original program files from the Flip!
In my case, I think my computer's processor did not meet the minimum system requirements of the newer FlipShare software. The original "Flip Video For PC" software requires a 2Ghz P4 or higher; the FlipShare software says it requires a dual-core 4Ghz or higher. So when the FlipShare software tries to load the ippvideodecoder.ax module on an under-powered processor, it just crashes. Bad design.
I bet that most of the people posting this same problem here have processors that are "borderline".
Anyway, here's how to get the original Flip Video software back and re-install it on your computer:
Disclaimer: I assume no responsibility if you screw up your Flip or lose your videos. I can only tell you this method worked for me.
1) Use Control Panel, Add/Remove Programs to uninstall FlipShare and 3vix.
2) Download "Flip Video For PC" v3.7 from here:
http://www.theflip.com/app/prius/37/update/
3) Follow the written instructions here for formatting your Flip and reinstalling the software:
http://www.youtube.com/watch?v=JYc8N3dmxhU
Important: this guy tells you how to back up any existing videos on your Flip BEFORE you format it.
After formatting, I had some initial trouble with the installation not finding my (empty) Flip. Here's a workaround: the installation creates a folder called "FlipVideo Updater Support Files", and within that a subfolder called "files_to_install". Copy the entire contents of that subfolder to the root of your Flip. Re-run the installation and it should now be recognized.
4) Bonus: once you've got the old software reinstalled and working, you may want to disable the annoying "Upgrade To FlipShare" nag screen that bugs you every time you run the software. Simply browse your Flip and delete the following file:
[drive letter]\System\VIEWER\PD\checkForUpdate.txt
No more nag screen!
I hope this info is helpful to those who experienced the same problem. Flip tech support people are absolutely clueless.
best,
JohnB
Dec 25, 2008 | Pure Digital Flip Video Ultra Camcorder
Fargo Persona C25 Thermal Printer Logo
417 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Computer Links
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
