Question about Motorola Mobility SD4581 2.4 GHz Digital Cordless Phone (51960700100)
Strong echo for my voice
My Motorola SD4581 which worked fine for the year and a half I had it, suddenly developped a loud echo of MY voice (other party in conversation hears me well), so loud that i cannot really talk. This is the same for both handsets. Is there anything that I can do? It really upsets me, I certainly expect a phone to work for more than the paltry 1 year warranty...
ML
SOURCE: Motorola 580 handset not working
are these phones registered to your base? scroll around in the menu until you come to register and press the "-" key. then quickly press and hold the page button on the base unit. you will here the phone beep. should work now
Posted on Mar 23, 2008
SOURCE: key pad on corless handset is not working
call Motorola they will replace the unit. I recieved four from them
Posted on Apr 03, 2008
  • 51 Answers
SOURCE: Handset Speakerphone Problem
I would try reseting the system... to do so uncover the batterie compartment and then and find a litthe tiny button that says reset and press it with a pen/pencil or somthing that will fit and try again... if that doesn't work call your dealer and ask for a refund/replacement. i hope this helps
Posted on Sep 30, 2008
Maniscalco77
SOURCE: motorola md7161 keyboard not working
I know you may not have experience in taking apart the handset or small electronic repair but, it is actually very easy to do. I just bought the same phone set from goodwill for $6.99. The set looks great and actually almost in new condition.
However, I had the same problem with just one handset so, I figured it out so, my set would work properly and now after I fixed it, I have no problems and every handset works great.
Follow these instructions step by step and I assure you it will work again like new.
Step 1.) Take the battery cover off on the back of the handset and pull the cord out carefully from the battery wire to where it connects to.
Step 2.) Unscre the two screws that you see inside. Then, carefully seperate the front cover from the inside of the phone to gain access to the inside of the phone so, you will have access to the 3 small screws that will seperate the circuit board to gain access to the keyboard.
Step 3.) After removing the circuit board and taking out the keyboard and rubber keyboard pad. Carefully wipe all of the buttoms very rigously with an alcohol wipe pad and you will start to notice some plastice film start to come off. This is what you want to remove beacuse, somehow it causes those keys to stick.
Step 5.) After wipeing them clean and reinserting the pad to the cover, the screws in the holes, aliging everything back together and snapping the cover back on, screwing the 2 screws back in and replacing the battery and cover. Test it and you will se that it works just like it did when the phone was brand new.
Hope it worked for you like it did for me and good luck. :)
Posted on Aug 15, 2009
vqcb43
  • 1623 Answers
Mobile Phones and Acessories
    Verified Fixya Pro
    SOURCE: How do I get my Motorola Elite Flip bluetooth headset to stop echoing on the other end?
    Alesia-
    Try a reset: ELITE FLIP Reset to factory default
    Try changing setting: MotoSpeak 3 0 Noise Cancellation settings
    What device are you connected to? I see other have reported after an android update on NON-Moto Devices: Headset echo problems after Android 4 3 update Verizon Wireless Community
    Mark
    Motorola Support
    Posted on Feb 11, 2015
    Motorola reset
    Hi
    Are you talking about voice command on your device or voice command on your phone? Are you doing a long press or a short press of call button? it will behave differently based on how long you press.
    Mark
    Motorola Support
    Aug 19, 2014 | Motorola Mobility Tx500 Bluetooth Car Kit...
    CALLER SAY THEY VOICE ECHOING
    Have you tried to use the device with a different phone? You can also refer to the following link for you to reset your device to initial settings: H720 Reset to Factory Setting
    Best Regards
    Suny
    Motorola Support.
    Mar 20, 2014 | Motorola Mobility H720 89382N Bluetooth...
    Motorola SD4581 2.4 GHz Digital Cordless Phone won't stop chirping
    Bad contact between the phone and the base unit making the pair think they are low on battery.
    it probably wouldn't hurt to get some rubbing alcohol, and clean the charging contacts on the base station and the handset. Oxidation can build up, and depending on whether you normally leave the handset on the charger or not, that oxidation can interfere with the contacts.
    Feb 20, 2018 | Motorola Mobility SD4581 2.4 GHz Digital...
    Motorola tz700 echo
    Dave. Maybe your phone microphone isn't turning off. Try unpairing and re-pairing.
    Mark
    Motorola Support
    Oct 27, 2012 | Motorola Mobility Tz700 Bluetooth In-car...
    Bad audio - Sony BM-147 Transcriber
    This is a common symptom when the belt and pinch roller wear out. They will both need replacement.
    Nov 29, 2008 | Sony BM-147 Desktop Cassette Transcriber /...
    Microsoft VX-6000 audio problem - static noise coming from speakers
    My webcam VX6000 picture is fine, but when i try to talk to anyone or do voice playback there is a loud echo and distortion both for me and the person i am trying to talk to. I have tried everything in support. I am running windows xp.
    Dec 27, 2007 | Microsoft LifeCam VX-6000 Webcam
    Echo Problems
    hit the sound icon on your desktop rightclick it, go to Recoringtools turn down the microphone! As in the picture.
    Im sorry its dutch :-)
    Jan 21, 2018 | Motorola Mobility H500 Wireless Headset
    Motorola Mobility SD4581 2.4 GHz Digital Cordless Phone (51960700100) Logo
    49 people viewed this question
    Top Motorola Mobility Lands Phones Experts
    John Donghia Jr.
    John Donghia Jr.
    Level 1 Expert
    Eric Sutherland
    Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
