Question about Toshiba TP50H95 50" Rear Projection Television
Replaced STK392-110 convergence chips in tv
I successfully replaced the bad chips in the tv. It powered up fine. I don't have a remote control for the tv and I am ordering one. However, the red has shadowed and doesn't look like it is lined up. When I access the menu to get to the convergence, the buttons on the front of the set don't allow me to move the blue or the red. The operators manual for the set doesn't address this. Must I have the remote to fine tune the picture? Can I open the set and adjust the red convergence line? Any help would be appreciated. Thank you for the excellent tip yesterday on performing the process. A+.
I found this TV out at a dumpster at an apartment complex and thought, "Why not." Twenty-five dollars later and I have a tv with just this minor problem.
  • j3738 Dec 07, 2007
    Also the red looks like it is out of focus.
    Genius:
  • 1,694 Answers
1) You will need the original remote for alignment...
Note: Do not open set to adjust red line.....
2) Remove lower front speaker grill cover and possibly the
access panel....find RGB focus / screen block...adjust red
focus...................................T.
P.S.remote control part 23306269 $26.90 ...........
Posted on Dec 07, 2007
Hitachi 57uwx20b
The resistors are all marked with bands which denote the value---just check them with a ohm meter===no need to replace out of hand.
When you replace the chips: remove all the old white grease and apply fresh heat sink compound (thermal transfer grease.
I see lots of people who want to "change everything" and usually get in trouble----for the most part these parts are either good or bad.
You will need the original Hitachi remote when done to adjust convergence in the Decam mode.
Mar 07, 2012 | Hitachi 53UWX10B 53" Rear Projection...
How Do I fix the convergence on my 2001 Hitachi Projection Tv
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos aroundimages.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 05, 2012 | Hitachi 53UWX10B 53" Rear Projection...
Color alignment
Your TV most likely a convergence failure. ( common problem )
  • Screen looks 3D
Here are some photos of convergence problems.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Mar 29, 2009 | JVC AV-48WP30 48" Rear Projection...
Bowing at top and bottom, can't adjust convergence replaced IC
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Mar 22, 2009 | Toshiba 57H81 57" Rear Projection...
Convergence Problem
  • Screen looks 3D
Mar 13, 2009 | Philips 60PP9202 60" Rear Projection...
Need schematic for Convergence PWB of Hitachi
  • Screen looks 3D
Mar 09, 2009 | Hitachi Televison & Video
Convergence will not line up after replacing ic & resistors
Did you replace the resistors when you replaced the convgence chips? If one of them was bad you would still have the problem.
Here are some of the most common symptoms and example photos.
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 03, 2009 | Philips 51PW9303 51" Rear Projection...
Convergence without a remote control
you will need the origional remote you can get one fast through this link just enter the model number www.replacementremotes.com
its normal after an IC change for the convergence to need adjusting, universal remotes can sometimes do it, but i have only seen that happen once or twice usually they wont have the right feature to adjust then save the settings.
Mar 29, 2008 | Toshiba 43H70 43" Rear Projection...
Pt 53wx53 convergence
Same here,sorry I can ajust all but it just wont come in perfect.
What is the problem.Will the sevice menu work?
how do you get it?
Dec 16, 2007 | Panasonic PT-53WX53 53" Rear Projection...
I have a double picture on screen i could hear my TV but the color are off too with Sony RM-Y908 Remote Control? which is broke
You may have a convergence problem. Here are some of the most common symptoms and example photos.
  • Screen looks 3D
2c07611.pngSolution
Oct 29, 2007 | Sony KP-57WS500 57" Rear Projection...
Televison & Video Logo
175 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
