Question about GE Nautilus 24" Built-in Dishwasher
GE Nautilus Dishwasher soap door
The motor to the timer stopped working so I replaced it. Everything was fine in putting it back together but I'm unable to figure out how the soap door latch is suppose to go back. I can't seem to get it to function correctly. I don't know if I have the soap door lever in correctly. The dishwasher is a GE Nautilus GSD3610F00A. Thank you for your help.
Kevin
  • 52 Answers
Click here to view the diagram. Hopefully it will help answer your question.
Posted on Mar 25, 2008
When I took the timer off of the door to replace it, a white lever that connects with a black lever which both together help open and close the soap door came off, along with a spring. I can't for the...
Explanation I am afraid may not work right unless you calm down and sit in fron of te unit with the lever and spring to be pushed back to the slot. This is the triger for the soap dispenser when the timer come to this program- it initiates the lever to dipense the soap. So use logic with time and you CAN do it if you can replace the timer. However if this is not there that function will not work and hence the cleaning may not be good.
Imagine the function,and piece the items to put the puzzle right.
The lever is for the link to open and the spring for it to come back.
Hope this helps . Good day
Aug 18, 2010 | GE Nautilus 24" Built-in Dishwasher
Suds, overflowing out of dishwasher
Its old get a new one these are not designed to last more than yours did.
May 11, 2010 | GE Nautilus 24" Built-in Dishwasher
No water goes into dishwasher. Dishwasher has only been used 2times. Came new with house 3.6 years ago. Pulled front panel off...everything appears to be connected motor fan runs.
I've experienced the same thing. Try very slowly rotating timer dial, click by click, until the water starts. Sometimes 3 or 4 clicks will start water. (You're advancing the clock.) Usually water starts in before the dial points to, "Short Wash." If this doesn't work, advance the dial to, "Off," unlock and open the door, reset, close, the soap dispenser, close and lock the door, and slowly advance the dial until the unit starts. I think this problem is a clock to pump issue and what I've described does a reset of the system. This happens to me once or twice per month. Poor engineering but still better than buying a new machine...at least 'till now.
Jan 04, 2010 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Soap and water coming out the front of the dishwasher
I would think that the gasket is not doing the job, can you pull the gasket together to decrease the gap. If not then try another gasket if it's not on warrentee
Apr 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Dishwasher - The soap door is stuck partcially open
Advance the timer, with one hand on the dispenser door. The timer should release the door at times during it's cycle, it may need a little help, but not very hard to turn.
Jun 27, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Soap does not dissolve
What is happening, is that your dishes are washing dry. Start the dishwasher and slowly turn the timer till it starts to fill. Let it go and see how they are after
Jun 20, 2008 | GE Nautilus 24" Built-in Dishwasher
Need Help !!!!
This is pxl8tr and I solved the problem by cycling the timer through, and the geared timer linkage automatically aligned with the soap dish!
Mar 23, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
383 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
