Problem with Mastercool 67471 Evaporative Cooler Air Conditioner
I need a wiring diagram for a mastercool evaporative cooler
Posted by avatar on Sep 03, 2009
Solutions (1)
Best Solution
Here is a link to the owners manual for the new Symphony brand evaporative cooler. Symphony is the new name for the old Adobeair brands Mastercools.
The owners manual will have the motor and pump wiring schematic.
Suggested Solution (3)
I have the wiring diagram in the cooler. I can photograph and send it to you. Do you still need it?
  • by Author image lfmb05 Over a year ago
    • By avatarleentom87 Apr 03, 2011
    • i need the same diagram can you please send it to me. thanks in advance
Source: Need a wiring diagram for mastercool evap 2 stage unit
Was this solution helpful?
No
Yes
These pads are available in different sizes and styles at home improvement stores like LOWES or HOME DEPOT (in season)
  • by Author image Jeff Barton Over a year ago
Source: need replacement pads for mastercool mrc55wa
No
Yes
The pump is probably gone. the way it works is a float allows the water level to stay the same in the reservoir so check that. Water is pumped up to the hoghair and trickles down into it. A big old blower pulls the wet outside air into the room. We call that one a swamp cooler down here on the gulf. Go outside and spray some water on the unit to cool down the house till you can get the pump replaced.
  • by Author image JW Webster Over a year ago
Source: evaporative cooler not getting water from water line
No
Yes
Add Your Solution
See all Mastercool 67471 Evaporative Cooler Air Problems
