Question about Vizio L37 Television
Blue screen, no picture
Turned on TV, cable, no picture, just a blue screen, when I put the input to TV I get a black screen, but you see the light in the back of the TV. Hooked up another TV and all works great.
  • 137 Answers
Sounds like you switch the tv from pal to ntc or around.
Posted on Dec 24, 2007
  • wendy_hsu_44 Sep 21, 2011
    how do you switch it back?
Black screen with sound
My 47" LCD Smart T.V. was working fine last night. I got up this morning and I have sound but no picture. The VIZIO icon lights up as usual but I get no picture, only sound. From the time I turned it on, nothing appeared on the screen. I have already tried unplugging it for a while and still nothing.
Oct 24, 2012 | Vizio VO47L 47 in. LCD TV
Tv broadcasts in color, but dvd broadcasts in black and white is this a fault or a feature and how can i resolve it
It would all depend on what type of cable you are useing to connect the dvd to the tv.With component cables if you have the blue input in the red or any of the three colors mixed up then it could cause a black n white picture also if you place normal a/v cables into the component slot then you also might get black n white have seen alot of people put the yellow cord into the green female slot of the component input of the tv instead of the video in slot. If you have HDMI an a blu ray make sure you got a high speed cable with at least a rate of 10.2 Gbps or faster should not result in black n white but you will not get the picture clarity u should be getting an it also may cause screen blur or drag on fast moving pictures
Mar 29, 2010 | Televison & Video
How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Mar 27, 2010 | Vizio GV42L 42 in. LCD Television
When using component cables(red, green, blue )
The series of the cable should go green red blue into the back. if you put the green in the red and the red into the green it give the TV a red base to go off of for the picture so everything is red. The reason the green cable won't is because it transmits a black and white picture which allows it a nice base to add the green and red to.
Feb 24, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Need Help with tv problem
tiene que revisar la tarjeta de comvergencia
Aug 26, 2009 | JVC AV-48P575 48" Rear Projection...
42' polaroid tv wont show screen still
well if the light stays blue , that means its still on ...what you may need to do is go to your menue and select the setup selection and then go to tuning band.....i belive it will be on page 32 of you manual, under customising the setup settings....in order for the tv to start working it needs to be able to scan for channels.....if you are useing a cable company like comcast or direct tv...depending on how you pluged it into the tv ,(like using the input 1 or 2 , s-vidio, cable , ectra,)...you need to push the input button thats on the lower right side of your remote and select the propper input area as to how you hooked up your cable box
Dec 14, 2008 | Televison & Video
No picture
check the antena cable because there is no input signal , try to put other imput signal to see if work like DVD or other if yes then chech your cable or call your cable sender
Dec 10, 2008 | Protron PLTV-37 37 in. LCD Television
Attention No Video Input
Check your input cabling and connectors and make sure you have a good input signal. Put another tv on this same input cable and see what happens. Keever
Dec 20, 2007 | Philips Magnavox 27MS343S 27" TV
No image
Had the same problem, it is a problem with a surge in the motherboard...mostly from the TV overheating.
Oct 04, 2007 | Westinghouse LTV-37w2 HDTV
Vizio L37 Television Logo
848 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
