Question about Jensen VM9510 Car DVD Player
Jensen 9410 i just hooked up rca to the rear surround plugged them into my amp and ran speakers wires to my extr 6x9, but all i get out of the speaker is bass. No treble mids or highs. is it a player problem or is my amp adjusted wrong. all my amp settings are placed in the middle now and still no change.
    Problem Solver:
  • 11 Answers
Try plugging in the rca's to an alternate source to make sure your rear surround is plugged into the right place. (ie not the sub out on your receiver)
Then make sure you have all low pass filters turned off on your amp.
Last thing to check is to take a mp3player or something and get a headphone to rca adapter and plug it in direct to the amp to make sure the amp is working properly by itself.
good luck
Posted on Dec 07, 2007
Wiring diagram for jp12 subwoofer
your sub woofer has only one input to make it work. plug in your rca cables into the back of the sub woofer and the other end into the audio out or subwoofer out put on the back of your surround system.
also has 2 speaker inputs so you can expand your speaker setup. plug thos in and you can hook up 2 speakers to th output on the back of the sub.
Jan 29, 2011 | Jensen JPS12 Subwoofer
Jensen CD-510K hooking a 200 watt amp to it.Need to know what wires need to use to hook it up
rca cables for audio and a remote wire. just plug the rca cables into the plugs in the back of the deck and the remote wire (i suggest buying a thicker (speaker wire size) gauge wire since it allows you to get more power out of the amp) to the blue remote wire coming from the deck. you will also need an 8 gauge power wire (12 inches to 12 feet depending on where the battery and amp are) and an 8 gauge ground wire (no longer than 24 inches).
Aug 18, 2010 | Jensen Car Audio & Video
I need a wiring diagram for the jensen lxa400. Pushing 2 kenwood 6x9 (200 watt rms each) and 2 dual voice coil 12's (300 watt rms each) in a truck box. Everything is 4 ohm. Thanks, Curtis
you shouldn't need a diagram all you need is these items here.
purchase a 4gauge wiring kit
run a a power line from battery to amp with a in line fuse 6in from battery.
run a ground from car frame to amp. ( scratch paint and screw it down with an eyelet for good contact)
run a remote from radio to amp.(blue wire)
run rca's from the radio to the amp ( sub input on back of radio)
finally connect your speakers.
Mar 26, 2010 | Jensen LXA400 Car Audio Amplifier
Jensen uv10 amp hook up
how to power on the amp on my flip out headunit
Feb 07, 2010 | Jensen Car Audio & Video
Rear speakers not working
Your FM tuner will only generate sound from the front sepakers. CD's, Tape, and I guess mp3 player, as well, will only play through the front speakers.
I've included a link for the manual. The audio on this rig is pretty complex. read through the info, especially pages 11,12,13, and play with the audio controls.
http://support.radioshack.com/support_audio/doc61/61792.pdf
Aug 16, 2009 | RCA RT2500 System
Speaker Detect error Left Rear
Hey there.
I had the same problem until i figured out that if u dont have surround speakers connected it will be a error when trying to configure the rear surround speakers.
So if u are running a 5.1 system and have hooked up ur surround speakers to the back surround speaker port u have to change them to the surround speaker port.
Hope this work for u
Jan 11, 2009 | Audio Players & Recorders
2002 Chevy Cavalier audio wiring diagram
to the guy who is looking for the wire diagram, you can buy a wire kit for the stereo connection for about $60 from best buy or some other place like that. your car's door ding and some other things wont work with out it. hope that helps you some.
May 30, 2008 | Car Audio & Video
No remote from Cd player. What to do?
thats a car dvd player right what u would do is to take the back of the unit and look for the female ends of rca's on the unit that they will say rear out put hook them up and run them to the amp and i dont get what u mean about the remote wire but let me no if that helps
Apr 04, 2008 | Jensen A600HLX Car Audio Amplifier
Rear speakers
THE 4 WIRES SHOULD BE FROM THE REAR SPEAKERS THEY GET WIRED INTO THE SURROUND SPEAKER OUT POSTS ON YOUR AMP (MAKE SURE YOU DO NOT GO INTO SURROUND BACK THIS IS FOR 6.1 AND 7.1 SYSTEMS).WHAT ARE THE WALL UNITS? NEED MORE INFO TO TRY TO HELP.
HOPE THIS HELPED A BIT.
CABLE GUY
Feb 13, 2008 | Onkyo TX-SR605 Receiver
Jensen VM9510 Car DVD Player Logo
81 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
