Question about GE Spacemaker JVM1640SJ Microwave Oven
Ge Spacemaker My GE Spacemaker Microwave all of a sudden broke. The turntable stopped working and it doesn't heat the food anymore. The light still goes on when turned on and all else seems fine. Is there something I can do to fix it without calling a repair person? If it is the motor to the turntable, is this easily repaired by me? And what would cause it to stop heating?
  • Anonymous Dec 08, 2007
    I have the same problem! One night, it just stopped working and then our refrigerator failed us.
  • 4 Answers
If the oven is not heating food and the turntable is not rotating, it's a serious problem such a as a low voltage power supply, and up to replacing the magnetron (considering getting a gently used replacement oven on Craig's List or elsewhere).
If the oven has a turntable and is not rotating, that might be a separate (and easy-to-fix) problem by itself. I replaced mine, and it took 10 minutes.
If the turntable doesn't rotate, either the small ac motor has failed, or the coupling from the motor has come loose. Unplug the main power to the oven. Remove the 5 or 6 screws underneath the oven to remove the access panel to see the small ac motor. There will be an electrical plug with two wires connected to the small motor---unplug it. Take out the 2 screws that hold the motor in place, then inspect if anything seems to have come loose. If everything was mechanically o.k., then the motor is bad.
It's a fairly universal part number, a low voltage ac motor. Make sure that the voltage rating is the same when looking for a replacement. You could check on-line with a search-engine or Sears.
Good luck, hope this helps.
Posted on Apr 19, 2009
I have same microwave.
never had any problem till a recall was done about a month ago,then about a week later it started doing what yours is doing.
I called ge,and they were going to send a tech back out to check it.
Well,times being what they are my wife said she could not do without a microwave
and she was going to go by one.
I am mechanically inclined,electrically also,so i got a torx driver out,and took off the
front panel he replaced,after I had turned the power off of course,.
There are two switches to the left when you take off the fnt panel.
They are for the door,for some reason one of them had flipped the wrong way
and was not being pushed when the door closed.
you may have a bad switch,but it will be cheaper to repair than a new one.
On mine i flipped the switch and no more problems
Posted on Jan 23, 2008
  • GE Master
  • 9,098 Answers
It's probably the turntable motor, but also check the coupler / turntable support too.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here:
Posted on Dec 09, 2007
GE space maker JVM1640. Does not heat food.
with out a proper diagnosis, i would have to believe your magnetron is gone
Oct 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Mar 21, 2009 | GE JE1540 Microwave Oven
GE turn table microwave stopped warming food
my microwave 1640GB from GE suddenly cannot heat food and make some noisy sound. as it is mounting in the closet, it is not easy to replace. any solutions or suggestion
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave, Model J VM1650AB5 Not heating food
If you sure that lauder sound comes from turntable motor than it needs to be replace.
Nov 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
206 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
