Question about Nikon N55 35mm SLR Camera
FEE error message
My batteries died while loading new film. Managed to get new batteries (I´m on Easter Island) and loaded new film but each time I try to take a picture, an fEE message appears above the shot number. Help! I´d like to take some pictures while I´m here!
  • cll74 May 05, 2008
    FEE comes up reguardless of what lens I have on it. It still doesn't work with the setting suggested.
    Champion:
  • 206 Answers
To get rid of the pesky fEE just set your lens to f22 or f16 ( depending on what lens you have ) and that is all. You might also want to lock this setting in ( if it is a Nikon lens then the lock is on the side just above the lens aperture ring.
Posted on Dec 07, 2007
My Nikon F80 won't load y film automatically, it has a FEE error on the screen but i don't know what that is??
The lens you are using has the aperture ring set to something the camera cannot use. Simply turn the aperture ring to the largest number, usually a 22 or 32. Lock that ring if there is a lock and the fee should be gone.
Aug 31, 2012 | Nikon F80 35mm Film Camera
The error film loading message appears and I have reloaded the film several times and it will not advance. Help
sounds like the film advance motor died needs repairing at a qualified shop if you think the camera is worthy, since its old how much is it worth to you vs a new one
Feb 10, 2011 | Nikon N70 35mm SLR Camera
When i turn on my fuji polaroid cam, there is an "E" error message. I can't take any polaroid pictures with it altho the polaroid cam is loaded with film. Please help. Thanks
First, remove the remaining films from the camera. (while your camera is switched off) Second, press on both the shutter button and the power button at the same time. (to reset) Third, reload a new set of polaroid films into the camera.
Hope it helps!
Dec 26, 2010 | Fuji instax mini 7S Film Camera
FEE flashing above where # of pics is showing
Hello
Thank you for using FixYa for your problem
If you get an "E" after loading the film it means that the camera is still Empty and the film has not loaded properly. The most common cause is that the leader has not been pulled out enough past the red mark. I also like to place a sprocket hole on a sprocket tooth (I assume here that the N80 uses a sprocket drive system like other Nikons). When loaded properly the film should advance to frame #1.
Your "FEE" error is something else again and has nothing to do with the film. Apparently the film was properly loaded if you got that also. "FEE" is an aperture error which you get most commonly when you are in one of the auto modes (P or S) and you don't have the lens aperture set to the smallest aperture (largest number, usually f22). Set the aperture ring on the lens to the highest number.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 02, 2009 | Nikon N80 35mm SLR Camera
Chevy Equinox 5 disc cd changer. Car battery died which cycled cd changer several times. Now it just gives cd error message and I cant get the lone cd out and I cannot load a cd.
I had the same problem with my 2007 Equinox, 6 cd changer. I changed the oil, disconnected the battery as recommended. When I reconnected the battery, the single cd wouldn't come out. It was out of warranty so I ordered a complete new cd player from ebay, I installed it, spent the $120 for the dealer to unlock it, just to find out....It won't let me load any cd's. Every time I hit load, it appears as if it is gonna load, but the motor inside never activates. Let me know if you find the solution to your problem.
Sep 22, 2009 | Car Audio & Video
Paper not loading, sericr eror message 5100
Dear kamal,
Error code 5100 also come with LED alarm flashes in Orange/Green 2 times. This error happens when carriage part (carriage unit) is faulty so that carriage part cannot read film encoder properly. As a result, carriage part move on uncontrolled. But,in some cases, dirty film timing **** strip (Horizontal film encoder;available only in i series and above) may cause the same symptom. Try to clean film encoder by wiping it with moistened clothe first.
Remedial action:
  • Replace carriage part
  • Clean/replace film timing **** strip
Oct 31, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
My camera won't load film
Set your lens to the smallest aperture ( largest number on lens ) f/22 or f/32 and lock it in place with the small latch on the aperture ring. The camera won't operate in auto modes without the lens set there.
Oct 21, 2008 | Nikon F65 35mm SLR Camera
Camera goes into Shut Down Mode & Flashes the Letter H
Hey sonax,
This H error message means either the film is loaded incorrectly, or there is an internal malfunction in the camera. To determine if the film is loaded incorrectly you should take the film and the batteries out of the camera then reinstall the batteries and try taking a picture without film in the camera. If the camera allows it then the film was loaded incorrectly and I would refer to the camera manual for directions on how to load the film correctly. If the H error message persists then there is most likely an internal malfunction and I would have the camera looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 23, 2008 | Canon Sure Shot 65 35mm Point and Shoot...
F-100 Won't take any shots
fEE blinking is Nikon's error message for cameras that control the aperture from the body instead of the lens. You need to set the lens to the smallest aperture (and lock it there, if the lens has a lock for the aperture setting).
Dec 27, 2007 | Photography
Fee to error
Remove the batteries for 5 or 10 minutes. Remove the lens from the body and replace it. Make sure the lens is on f22 before you put the batteries back in and turn on the camera. If this doesn't solve it, try rewinding the film you have in the camera and try a new roll. The other thing to check if none of the above works is to remove the lens and check the small tab just on the outside of the mount ring at about 7:00. The tab is spring loaded and you should be able to push it with your finger and it will snap back. If it doesn't, the tab plate will need repaired or replaced
Dec 25, 2007 | Nikon N55 35mm SLR Camera
Nikon N55 35mm SLR Camera Logo
193 people viewed this question
Top Nikon Photography Experts
Ric Donato
pictureman4u
TC CAMERA REPAIR.Com...
Are you a Nikon Photography Expert? Answer questions, earn points and help others
