Dryers Logo
Posted on Sep 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My admiral dryer just stopped heating what can the prob be.
Anonymous
Level 2:
  • Expert 135 Answers
  • Posted on Sep 03, 2009
Anonymous
Expert
Level 2:
Answers
135
Questions
0
Helped
39997
Points
401
The heating element or the thermofuse is bad.
Dan Webster
Level 3:
  • Dryers Master 8,221 Answers
Dan Webster
Dryers Master
Level 3:
Answers
8221
Questions
5
Helped
2379094
Points
25840
It might have a problem with the blower wheel or lint in the filter housing. Before it quit did it take a long time to dry clothes? That is a sure sign of a dead dryer high limit failure. Located in the rear of the dryer beside the heater element you will find the limit. my admiral dryer just stopped heating what can the - 4e6fab4.jpg
from there you can get the front and drum out and locate the problemo on back. be sure to check the blower wheel fer looseness and git all that funk out dat drymy admiral dryer just stopped heating what can the - f8aad9d.jpgmg src="/uploads/images/f8aad9d.jpg" alt="f8aad9d.jpg" class="h_mi" />
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
  • Dan Webster
    Dan Webster Sep 03, 2009
    The Thermal limit is the ****** you needs ta change:
  • Dan Webster
    LA 1053 is the part number. and I cant imagine why the filter blocked out thang. LOL
Admiral Dryer. 6.5 cu. ft. Electric Dryer in White AED4675YQ0 will not stop heating will not cool down AND IT SEAMS AS THO THE HEAT ELEMENT IS STILL ON WEN TIMER IS AT AN OFF POSITION
It sounds like the heat element is bad. It is touching its metal housing causing it to be grounded. It is supplied with 120 volts so it will stay on. You will need to replace the heat element. In the mean time unplug it or turn the breaker off.
Admiral Dryer, runs bu t does not heat
The thermostat, timer or the heating element itself are the places to check. Look at the circuit breaker for the dryer in the power panel. It will be two breakers connected together. If one trips but not both, the heating element will not heat but the dryer will run.
Admiral dryer timer not turning and no heat
It could be the high temp fuse on the element and the timer not turning depends doyou have it on the auto dry because it will not advance if it is not heating because the sensors are not detecting a decrease in the humidity levels because the element not working.
1helpful
Admiral Dryer Model #AGD4475TQ No Heat
This is very rare on a gas dryer but I have seen it. If you have already replaced all that other stuff I would say it has to be inside the timer. On one I worked on once I could remove that orange wire and the dryer would function ok so I ordered a new timer, they sent me a bad timer. Same problem. I finally got a working timer after going through a bunch of mess. That fixed it. So if all the other components are working it very well could be the timer.
3helpful
Dryer suddenly stopped heating
Heating element, thermostat or thermal fuse
1helpful
Admiral Gas dryer will start to heat when first turned on then goes cold. The dryer will not stop running but will not heat. Any help would be appreciated. Thank you Jason
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
1helpful
Admiral Capacity Plus LNC8764A71 stopped heating up, Otherswise fine. Cleaned lint out of front and back. What next?
If this is a gas dryer, you might want to check your thermal fuse. If it's not glowing on start up, replcae it.
1helpful
My admiral dryer runs but has stopped drying the clothes to where I have to run the load five or six times and when I take out the clothes they are cool instead of warm. It does this with every drying...
either your heat cycling switch,hi-limit switch,thermistor or part of your element is defective or you don't have full 240 volts to operate your dryer i.e. only 1 leg of 120 volts it will run in some cases but will heat poorly
Heating element
Might I suggest this site if you are a do it your self.
http://www.appliancerepair.net/dryer.htm
You have to raise the top take off the front and the tub should come out. Wala the heating element. Hope this helped, if not let us know.
Mar 16, 2009 • Dryers
Top Dryers Experts
john h
