Acer 9300 series Laptop
I need to know where to locate the bluetooth connector on my laptop, its not under any of the removable panels, if its under the top how do you remove it
John
    Problem Solver:
  • 9 Answers
This is the link to the users manual from Acers website http://csd.acer.com.tw/acer/URMUL1.NSF/1af87a750eeeb70f0825628f006e0bfc/bc1dbebef07c65dc482572aa0020980e?OpenDocument . On page 20 of the document or page 38 if you are using Adobe Reader it will show you the panels on the underside of your laptop. The one labeled “#3 Mini PCI card bay” should be the one to remove to get to your Bluetooth card. You'll need to unplug both the white and black wires and then on eachside of the cad there will be either plastic or metal clips holding the card in the socket. Push out on the clips at the same time, this will release the card. Pull it out at a 45 degree angle. Be sure to place it back in at a 45 degree angle or you could damage the socket.
Posted on Dec 17, 2007
  • 31 Answers
If your laptop has already inbuilt bluetooth facility then here is the solution. There are three removable panels under the laptop
1. HardDisk
2. RAM.
3. Bluetooth.
The Bluetooth in laptop appears as a card inserted in a slot with two wires connected to laptop motherboard colored black and white.
Posted on Dec 15, 2007
I want to fit some extra memory to my Acer Aspire 9300. Which door do I open on the bottom of the notebook. thanks.
You can adding RAM to your Acer Laptop by following the below steps.
1 . Unplug your laptop from the AC power source and remove the battery.
2 . By unplugging the power connector you will be safe from shock.
3 . Locate the memory access door for the main memory module. It should be on the back of your computer.
4 . Unscrew the memory access door and remove it.
5 . Remove the RAM module by applying gentle outward pressure to the securing clips on either side of the RAM module until they release.
6 . Rotate the RAM module upward to a 45 degree angle and slide it out of the slot.
7 . Align the new RAM module with the tab in the connector slot.
8 . Slide it firmly into place and gently rotate it downward until it clicks into place.
9 . Replace the memory access door.
10 . Replace the battery and power up the computer. It should recognize the added memory and reconfigure itself for use.
Hope the above information will be helpful to you.
Thanks for using Fixya.
Nov 23, 2010 | Acer Aspire 9300 Notebook
I can not get my Acer 9300 completely apart to switch out fan with out breaking it. I have the screen off but with out breaking wires i can not put back on i can not open it up.any suggestions?
The fan is located in the bottom of the laptop. You just have to take out the screws in the bottom remove the bottom panel and there should only be 2 or 3 screws holding it in.
Apr 29, 2010 | Acer Aspire 9300-3716 Notebook
Hello, acer 5535 Laptop, internal bluetooth problem
your laptop uses a foxconn bluetooth set. Make sure you have the proper driver for this device. Go to Acer support and make sure the driver is up to date. May look something like this:
Fox_brm_2.0 F/W 300
I believe this laptop is still using the bluetooth standard 1.1, so there shouldn't be an issue with finding another bluetooth device. Just make sure that the other devices are in discovery mode or they won't be seen regardless. Discover mode should be able to be accessed through the options tab under bluetooth. Good luck, ParrotHead PC Repair
Sep 06, 2009 | Acer Aspire 5535-5050 Notebook
Screen has different color lines through it (acer aspire 9300) the picture of what ever web site i"m on turns into different color lines
Connect external monitor and check if the video is good that mean the vedio card or the driver is corrupt...try reinstalling the driver if issue persistes then video card is fautly.
Regards
Priti
Aug 24, 2009 | Acer Aspire 9300 Notebook
Acer Aspire 9300 turns on with black screen
Hello!!
Try entering thro the safe mode ... and restore the system. let me know the updates.
Cheers!
Jun 23, 2009 | Acer Aspire 9300 Notebook
Bluetooth location on acer laptop
Bluetooth other than the device itself is software, the "bluetooth dongle" gets plugged into a port via the usb, So I am thinking you need to plug it in to the computer. If it is a new machine if may be internal, that would be under programs, start programs, if no bluetooth it must be installed the software and hardware, good luck
Dec 18, 2008 | Computers & Internet
How to use bluetooth in aspire 5600awlmi Hello. I also have a Acer Aspire 5600 and I can see the bluetooth sign on the tools bar at the bottom of the screen, but when I click it it says: "bluetooth device...
Does the acer 5600awlmi have a bluetooth device installed?
Do you have a switch at the front to switch bluetooth on/off?
Check by opening back were the harddrive is also located.
If no card with 4 wires on white 8-pin socket is installed, you don't have a bluetooth device.
Also check the connector!
However it is possible to put one in yourself.
I have a 5601awlmi and mine has no bluetooth device installed.
On e-bay you can buy an bluetooth card for approx. €20 in germany.
On the back side open the casing were the harddrive is located.
(front left)
There you see a 8-pin white socket.
Connect the card to the socket and boot.
Next install the bluetooth drivers from acer website if neccessary.
I hope this answers your question.
Greetz. T.J.
Dec 07, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 9300 laptop 2007 year
i cant change my user account
please mail me on rajesh_mengavarm@yahoo.co.in
Feb 20, 2008 | Computers & Internet
Computers & Internet Logo
Alun Cox
David Payne
David Payne
