Question about Miele CVA610
Locked into warming up mode
The espresomachine worked for 2 years without any problem, then did not start up anymore. The display shows warming-up with 3-5 dots, but does not go into brew mode. Miele service replaced heater/temp control module, and asked $800 for this ( waived finally). Claimed that the problem was caused by power transformer. This transformer was necessary, because it was 220 V demo model. Capacity of trafo is 4000W. How can this be the cause if the unit worked for almost 2 years?
Anyway after the repair it worked for 2 months and then stopped. Occasionally it goes into select product mode after power-up and then produces a luke warm cup.
Can it be repaired at reasonable cost or is it ready for landfill ?.
  • koffiegek Dec 10, 2007
    Dear Timid,
    This sounds reasonable, but does not help me much, since I have no idea who this local professional would be. The machine is in Falmouth, Ma.
    I am afraid this machine is not so common, so to find a local professional is not so easy. Perhaps you know someone better than the Miele technician?
  • Dan Bendtsen Aug 07, 2013
    I have the same issue with my Taleo Touch. I am tire of large fix-it bills
    Novelist:
  • 173 Answers
According to this current situation, you can check witha local professional..b-cos the internal circuitry has to be checked..
check with him if it can be repaired..if not you can replace it..
Posted on Dec 07, 2007
How do i change the time on T5K801 Marathon watch
To set time and date:
1) With time and date showing,
press SET and hold for 2 seconds.
2) Seconds flash. Press START/STOP to set seconds
to zero.
3) Press MODE
Hour flashes.
Press START/STOP
to change hour, including AM (no symbol) and PM.
4) Press MODE
Minutes flash.
Press START/STOP to change
minutes; hold button to scan values.
5) Press MODE. Year flashes.
Press START/STOP to change year.
6) Press MODE
Month flashes.
Press START/STOP
to change month.
7) Press MODE
Date flashes.
Press START/STOP
to change date.
8) Press SET
, at any step, to exit and save settings.
With time and date showing, press SET
to switch between 12- or 24- hour time format.
Date (day of month) appears in upper part of display in Time
mode. Press and hold START/STOP
to see month, date, and year in large digits
Or go to:
http://assets.timex.com/user_guides/Marathon/W292-Marathon-AllLanguages.pdf
Jul 31, 2017 | The Watches
Nokia 6350 1dr restriction code
Hi
Dial using the keypad: * # 06 # - IMEI number is displayed on the display.
SimClock
Allows you to check whether your SIM-card mode StopClock. When transferring the card to this mode significantly reduces power consumption and thus increases the work of the battery. Generally, all modern SIM-cards support this mode.
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display (operator logo).
*#0000# To view software version.
*#2820# Blue tooth device address.
*#746025625# Sim clock allowed status.
*#62209526# - Display the MAC address of the WLAN adapter. This is available only in the newer devices that support WLAN
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
Displays Serial Number.
Displays the Month and Year of Manufacture
Displays (if there) the date where the phone was purchased (MMYY)
Displays the date of the last repair - if found (0000)
Shows life timer of phone (time passes since last start)
ttt
txexixs
Feb 27, 2017 | Nokia Cell Phones
My casio cash register PCR-T2000 won't go into z mode anymore. when the key is in the z mode, the display shows "x" and it doesn't respond to any inputs. Searched the manual and online posts. Suggesti
Your machine needs a service. Get a qualified tech to service the Key slot for you you will be fine or you might have to replace it altogether. Good luck
Mar 03, 2014 | Casio PCR-T2000 Cash Register
Delonghi cf208 the dehumidifier mode does not seem to do anything, any suggestions
I have the same model. It works brilliantly as we tend to dry the washing inside this time of year. When on dry mode try turning the "set temp" down to 17'c this normally starts mine off,,, failing that put some washing in a warm room with the dehumidifier "temp set" at 17'c just to test it maybe. or perhaps its just not humid enough where you are placing it? Good luck.
Sep 15, 2012 | DeLonghi CF210 Portable Air Conditioner
How to set date and time
Set the date and time:
The current date and time are shown in the display when the machine is on and ready for use (Ready mode). The date and time will be printed on all faxes you send.
1. Press Menu.
2. Press Left Right Arrow to choose SET DATE & TIME and press Start/Enter.
3. Press Start/Enter when the display shows Date Format.
4. Press Left Right Arrow to select either Europe (day month year) or USA (month day year) and press Start/Enter.
5. Press Start/Enter when the display shows Date & Time.
6. Set the date and time. You can move the cursor by pressing Left Right Arrow.
7. Press Start/Enter when the date and time are correct.
1-AM 2-PM will display.
8. Press 1 or 2.
Dec 07, 2010 | HP 1050 Plain Paper Inkjet Fax
Programing a new remote
Use these instuctions if your Deville has an Analog Instrument Cluster
1. Press OFF and WARM buttons on Climate Control Panel (CCP) simultaneously.
(Instrument Panel Cluster (IPC) will light all telltales, then go blank) System is now in diagnostic mode.
Press PASSENGER COOLER button until “RFA” is displayed, then press FAN UP.
If “RFA DATA” is displayed, press FAN DOWN.
If “RFA OVERRIDE” is displayed, press FAN UP.
2. If “RFA 500 NO OVERRIDE” is displayed, press FAN DOWN.
If “RFA 501 PROGRAM FOB #1” is displayed, Press FAN UP.
3. IPC will show “0” on right side of Driver Information Center (DIC) display.
Press warmer button on climate control unit until “99” is displayed.
4. Press and hold TRUNK button on transmitter. While holding TRUNK button, press LOCK button and hold for one
second. Hold both buttons for a total of 3 seconds. Locks cycle when programming is complete (if remote is not
programmed within 30 seconds after entering “99” override display, system will default and you must begin again at
step 2.
5. To program a second remote, press FAN DOWN button until “RFA 502 PROGRAM FOB #2” is displayed, then press
FAN UP. Repeat step 4.
To exit system, press AUTO, MODE UP, MODE DOWN, or RESET.
Use these instructions if your DeVille has a Digital Instrument Cluster
1. Press OFF and WARM buttons on Climate Control Center (CCC) simultaneously. Instrument Panel Cluster (IPC) will
light all telltales, go blank then enter DIAGNOSTIC
MODE. Press FAN DOW button to scroll through system until
“RFA” is displayed, then press FAN UP button. Press FAN DOWN button until “RFA OVERRIDE” is displayed, then
press FAN UP button. When “NO OVRD RF 500” is displayed, then press FAN UP button.
2. When “PGM FOBL 501” is displayed, press WARM button and “99” will be displayed in left upper corner of IPC just
below odometer. System is now ready to program remote.
3. Press and hold TRUNK button on transmitter. While holding TRUNK button, press LOCK button and hold for one
step 2.)
4. To program second remote, pres FAN UP button until “PGM FOB2 502” is displayed, then follow steps 2 and 3 to
program second remote.
To exit system, press RECIRC or RESET buttons.
Disclaimer
Apr 25, 2009 | 1998 Cadillac DeVille
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
My Spectra XL44 suddenly refuses to ignite the baking portion of the oven - broiler and top work just fine. The day before it was working fine. Wondered if it was an electrical egnition problem - gas feed or what??? Help!! Mregressor@aol.com
Nov 13, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
Miele CVA610 Logo
347 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
