Question about Amana NAV5805A Top Load Washer
AMana top washer LWA 65/a
Our washer won't spin and drain for heavy loads. With light loads it's alright. Can this b repaired? If it is the belt can I repair it myself? thanks
  • 185 Answers
There is no belt its a coupler between the motor and the transmission
Posted on Mar 26, 2008
  • ds7734 Jan 20, 2011
    wilbur, this ia a whirlpool type washer. there is a belt that drives the transmission AND the drain pump.
Amana NTW475OYQ1no lights or sounds. Verified power @circuit board. Someone closed lid on a shirt earlier that preventing lid to I open.verified switch waz working and the wife did a load of laundry.
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
Sep 6, 2013 - Uploaded by
Troubleshoot your Admiral Top Load Washer that has these following ... Speed Queen, Amana Whirlpool ..... Lid lock lightflases; no spin cycle.
Amana Washing Machine NTW5400TQ1 Troubleshooting ...
Amana Washing Machine NTW5400TQ1 Troubleshooting & Repair Help. Amana Washing Machine problems. Washer won't spin · Washer is making loud noise ...
Jan 16, 2016 | Amana Washing Machines
Spin cycle does not appear to complete it's cycle/ drain all the water. Is this a belt or motor issue?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Aug 14, 2011 | Amana ALW480DA Top Load Washer
Washer fills, agitates, won't spin. Makes buzzing noise. Amana LWA50AW
Most likely it could be the forward belt . When the machine is under load you hear a winding noise it sounds like the pulley belt tensioner. One other thing to check the rinse and hold button is activated as in the past accidentally people have switched it off.
Jul 26, 2011 | Amana 3.2 cu. ft. Top-Load Washer
Amana washing machine (ALW880QAW). Does not work in spin cycle. Washer works ok in wash cycle, and in draining water, just the new belt is too loose when it switches to spin. It just burns up the belt....
probably the lid switch is faulty,remove screws behind control panel,then pull control panel toward you and lift up and lay back,now remove 2 screws in the lower front panel by the floor and remove the cover,then 2 more screws to remove upper front panel above the lower one,then 2 more screws in front hold the top on then raise top up like a car hood and the lid switch will be under the top cover
Mar 23, 2011 | Amana ALW880WH Top Load Washer
Tighten the belt on an Amana washer?
The belt should already be pretty tight after wrapping around the barrel and the motor pulley. The belt may be worn and should be inspected and probably replaced.
To prevent similar problems in the future I suggest you be aware of how big of a load you put in the washer.
Mar 13, 2010 | Amana 3.2 cu. ft. Top-Load Washer
No, the pump works while spinning. The burnt smell is probably the belt, especially if your wife saw smoke. Did she put a big load in it at the time?
The belt will slip until the tub catches up with the motor. If there is a heavy load, it can burn the belt up. I would replace it. Make sure the idler pulley on the motor moves freely also.
Jan 22, 2010 | Amana ALW480DA Top Load Washer
Front loading washer won't spin
my amana washer wont spin and does not drain
Sep 11, 2009 | Kenmore Washing Machines
Amana NAV5805A Top Load Washer Logo
232 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
