Question about Fahrenheat ECP1524 Wall Mounted Panel Heater
Fahrenheat wall unit
Our fahrenheat wall heater (no thermostat, just an off/on switch with a few heat levels) turns itself on and off even when the switch is rotated to "on."
we'd like to use the heater but don't want to be paying for electric when we don't need it! what should we do?
  • maeg Dec 07, 2007
    sorry, i meant "even when the switch is rotated to "off".
  • 625 Answers
Your on-off switch is faulty - need to replace it.
Posted on Dec 09, 2007
My fahrenheat fuh-54b won't stay running long enough to heat
Most likely defective thermostat or heat sensors on the unit
Nov 28, 2013 | Fahrenheat 5,000-Watt Unit Heater FUH54
Do you have a thermostat switch for sale the # on it is L1345F
Hi, Nothing is sold here...
Here is a tip that wrote about how to buy heating and air conditioning partsonline.
How to find Air Conditioning, Heating and Furnace parts online.
heatman101
Apr 24, 2011 | Fahrenheat VFK404 Electric Wall Mounted...
I have a fahrenheat wall mounted heater, 120 v model,(can't find a model number on the unit) with a dial temp control. No matter which number setting it is on, the unit cycles off after about 50 seconds....
UNIT SOUNDS LIKE ITS SHUTTING DOWN ON A LIMIT SWITCH IN HEATER. THEY LOOK LIKE ROUND BUTTONS OF DIFFERENT SIZES. THE HAVE 2 WIRES GOING TO THEM AND THEY ARE A NORMALLY CLOSED. THERE IS A FAN DISK NORMALLY OPEN TO UNTILL IT GETS HOT AND CLOSES TO TURN ON FAN.  IF THE FAN SWITCH TAKES TO LONG TO CLOSE THEN LIMIT OPENS TO PROTECT FROM OVER-HEATING
Apr 23, 2010 | Fahrenheat (FFH1614) Wall Mounted Panel...
Thermostat for Fahrenheat 5000Watt Ceiling mount heater
You could do it. It would mean serious wiring though and you should use the factory thermostat because it is designed to operate on 240 Volts. Or you could use a remote thermostat at low voltage to throw a relay in the heater and get it to come on. The manual has good diagrams on how it is wired and it would not be too hard to do. IT would operate just like the outside unit on an HVAC system .
Oct 26, 2017 | Fahrenheat Electric Convector Baseboard...
How do I wire up a F2544 baseboard heater with a single pole themostat
It sounds like you are not getting the correct voltage for the heating element. If you wired a single pole thermostat, and its a 220v unit, then it will not get hot enough, like you are saying. If its a 220 heater, you need a 2p2t thermostat. The parts supplier will know what this means.
Mar 17, 2008 | Fahrenheat Electric Convector Baseboard...
Can someone please tell me what is the lowest temperature setting a Fahrenheat 3000 Watt Large Room Fan-Forced Wall Heater Model FZL3004 will turn on at ?
about the only way I can figure is to let the room get very cool and adjust the thermostat to its lowest setting. now turn on the unit. monitor the heat until the stat just opens. the thermostat bimetal will be closed and will open when the bimetal expands and opens its contacts. another way is to hitch up a chart recorder to measure temperature with its output connected to the heater. [too expensive for you or the DIY to accomplish]
Dec 13, 2007 | Fahrenheat FFH1615 Heater
Fahrenheat ECP1524 Wall Mounted Panel Heater Logo
190 people viewed this question
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
