Question about IBM Wheelwriter 30 Typewriter
Problem with striking
Won't strike the correct key. Error message says KYBD 099
  • IBM Master
  • 3,594 Answers
Sounds like a keyboard problem. Check the connectors to be sure they are fully pluged in, if this isn't the problem try putting a piece of foil over the rt hand keybourd connector contacts that are bussed together (seven I believe) replug the ketboard and test. BE SURE TO BUSS ONLY THE CONNECTORS THAT ARE BUSSED ON THE CONNECTOR!!
Posted on Dec 24, 2007
Swintec 2500 printhead won't strike the cartridge ribbon.
there is a rubber seperator that is bad this will not let it hit hard enough to strike the print wheel. your local typewriter shop should take care of it.
Feb 01, 2017 | Swintec Office Equipment & Supplies
Non system disk or disk error' 'replace and strike any key when ready' 'Media test failure Check cable' When l performed the Boot Utility test it returned an error message 'f
Sounds like a disk issue. It kind find the OS so it's then trying to PXE boot (boot from the network). Have you changed the boot order recently? or do you have a USB key connected to your server? are you able to connect to the management interface (hp ilo, dell drac) to see if you had any raid or other hardware issues?
Jan 09, 2013 | Computers & Internet
Why won't system disk error leave when "strike any key action is performed?ed
Check on your operating sytem DVD or your HDD might be not reading well. ( Freezing, Hanging )
Sep 08, 2012 | HEWLETT-PACKARD HP G56-122US Notebook
IBM Wheelwriter 30, Series II has message KYBD 099
Tour keyboard is going bad. Hold the code down press lang (L) key release the "L" type 001, release the code key this should put you on U.S. keyboard mode. For a better repair you can try my tip under WW1000 or contact Geo Beyers Co. @ 800-392-8085 for a keyboard rebuild. Tell them O'Reilly sent you.
DickyO
Nov 10, 2010 | Lexmark Wheelwriter 2500 Typewriter
KyBD 099 what is it and how do get rid of it
Your keyboard is bad. To use it temporaly hold the code key, press "L" type 001 (code for us keyboard), release code key.
For a repair see my tip under WW1000 or contact Geo. Beyers Co. @ 800-392-8085 for a keyboard rebuild, tell them O'Reilly sent you.
DickyO
Sep 14, 2010 | Lexmark Wheelwriter 3500 Typewriter
Need help
Is error happens mostly when usb devices or diskettes is inserted to the computer.. The computer tries to boot from them but when there isn't any boot data it just keeps making that error..
Just try to remove all extra usb-devices, cd's/dvd's and floppies/diskettes connected to the computer, so it's only monitor, power, mouse, keyboard and internet that is plugged in..
PS: Please rate this solution
Mar 11, 2009 | Ulead Videostudio 8 for PC
Displays error code "kybd 099"
Try this, hold the code key, press and release "L" key type 001, release "L" key. If this works the keyboard is going bad & will need replacing.
DickyO
Feb 18, 2009 | Lexmark Wheelwriter 2500 Typewriter
Wheelwriter 3500 KYBD 099
Check the ywo keyboard connectors to be sure they are plugged in fully, if they are then press & hold the code key, press & rel the "L" key type 001 then release the code key.
This will put you into the english keyboard mode. To cure the problem you need a keyboard.
DickyO
Oct 06, 2008 | Lexmark Wheelwriter 3500 Typewriter
Lamp will not strike error message
this can sometimes indicate either an overheating issue, a lamp service life problem, or that the cover to the lamp housing has not been secured properly.
Dec 14, 2007 | InFocus LP120 / 1000 Lumens / XGA / DLP...
IBM Wheelwriter 30 Typewriter Logo
64 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
