HP OfficeJet Pro K8600 Printer
Problem for HP OfficeJet Pro K8600 Printer
HP K8600 Intallation Fatal Error
By andy527 on Sep 03, 2009
Just bought an HP K8600 but get a "fatal error during installation' even though the computer says device driver software installed successfully.
The first thing that happens when I install is I get this error message "The path C:\ProgramFiles\Hewlett-Packard\contains invalid character.
When I go to look at the directory, I seen the files in a directory entitled Hewlett_Packard with an underscore, while the Hewlett-Packard directory has my HP 7310 All in One in it.
The printer works, but I get a growl or a buzzing coming from my computer or the speakers from my CRT as it prints. I also get no control panel during printing.
My O/S is vista.
Help!
Solution #1
posted on Sep 03, 2009
Somewhat Helpful)
Roonie Tunes
Rank: Guru
Rating: 88%, 56 votes
Ok... this one sounds a bit backwards, but have solved other issues like this:
Try uninstalling the HP software itself, and put the installation disk aside... power down your computer, plug in the printer, and reboot. Allow windows to discover the "new hardware" and INSTEAD of using the installation disk, have Vista locate the best driver (online if you can do it). Once you can get the printer to print with basic function, create a restore point in System restore (so you won't have to go through the initial driver install again if a crash occurs later), and THEN try and install the components you want from the installation disk. Again, it sounds backwards, but many manufacturers have had significant issues with Vista for stranger things. You may not even want all the "extras" HP includes with it's software (like online ink purchasing, photo editing, etc) but at least you can get the printer functioning!
Hope this helps!
-- RT
Was this helpful?
Yes
No
Popular Solutions for HP OfficeJet Pro K8600 Printer
Questions and Unsolved Problems for HP OfficeJet Pro K8600 Printer
Do you recommend HP OfficeJet Pro K8600 Printer?
Answer
Answer
insert the solution centre disk and click ok, this message appears every time i switch on the pc
Answer
HP Pro K8600 - Lid open light is flashing after lid has been closed. How do I fix it?
Answer
How do I get it to print on 12X12 paper. How do I do this on programs that print on 8.5 X 11?
Answer
print with autocad 2008 with 5 mm margins only
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
