You did not specify the kind of system you are using, but all thesame, i have the same problem with my sony dav-sb100. An expert said i need to get a modern (digital) tv set, also the system could be on permanent ntsc. if non of these are your problem then check your connections.
Was this helpful?
Yes
No
Popular Solutions for Sony BRAVIA DAVHDX275 Theater
When we close the disk tray on our Xbox 360, it closes for a second,then pops back open. It gives no...
(More)
When we close the disk tray on our Xbox 360, it closes for a second,then pops back open. It gives no error message, just to close the tray. Is it a problem new disk drive will fix or is it a communication problem between a working disk drive and the rest of the Xbox info system?
05 tahoe bose 6 disc and cd's are stuck and the cd light just blinks and will not play or eject...
(More)
05 tahoe bose 6 disc and cd's are stuck and the cd light just blinks and will not play or eject cd's,radio works fine
This is being played on a LCD flat panel, so I didnt think magnets in the speaker would affect the...
(More)
This is being played on a LCD flat panel, so I didnt think magnets in the speaker would affect the t.v. Satellite dish has no problems, PS3 has no problems playing the sound through the amp. But for some reason dvd's play back with a greenish haze.
This is a 5 dics player worked great only 7months old and no matter what disc I use 1-5 or fill all...
(More)
This is a 5 dics player worked great only 7months old and no matter what disc I use 1-5 or fill all 5 it just spins says NO DISC and trys the next one I've tried a Disc cleaner I really would appreciate any suggestions Thanks
