Question about GN Netcom GN 9330 Wireless Headset
Headset not working
It seems that the headset on my 9330 stopped communicating with the base so I can no longer use the headset. Has anyone else had this problem before and is it an easy fix?
  • Anonymous Dec 20, 2007
    The headset to my 9330 stopped communicating yesterday (12-19-07) I was on a telecomm and set the headset on my desk for about a half hour; when I returned and tried to make a call it was dead. My desk set functions and three of the four lights on the base are lit (the far right one is not)
    Is there a troubleshooting guide that will help or does someone have a solution?
Sounds like your headset isn't paired with its base. With the headset in the cradle press and hold the button on the left side of the base that has two arrows on it. You should see the blue light on your headset turn on. Its now paired to the base.
If that doesn't work, remove the battery from the headset. (This is the back piece of the headset.) Wait a few seconds and then snap it back on to your headset.
Good luck.
Posted on Mar 28, 2008
No dial tone through the headset
Hi, I wasn't getting any dial tone through the GN9330, using the headset port on an iQ750. I finally found a headset polarity switch on the bottom of the phone. I changed it from "V" to "P" and fixed the problem.
Oct 15, 2013 | GN Netcom GN 9330 Wireless Headset
How do I unmute my Jabra GN 9330? It has the red "lips" lit up at the bottom of the base.
You have the small switch on to off the ear piece that you use to adjust the volume, this also controls the mute function, just press the little blck switch in. That should un mute it.
Dec 13, 2012 | Jabra GN9330 Wireless Headset
While the headset works frequently, it will suddenly stop. Nothing I do will allow it to connect again. I hear nothing through the headset after the initial beep that indicates headset mode was enabled. ...
It sounds like the battery is no longer holding a good charge. There is no replacement battery for this headset. If you are using the original 510 headset you can replace it or pair a different bluetooth headset up to the 500A base. Just keep in mind if you decide on a different style of headset you will not be able to charge it in your base. I have included the link for the 510 replacement headset below.
Plantronics Voyager 510 Replacement Headset
Good luck from Headsets Direct!
Jul 14, 2011 | Plantronics Voyager 500A Deskphone Adapter...
The handset will lift when I press the mfb but I get no volume or mic from the headset. It does not seem to be communicating with the phone. Tried unplugging the power, but that didn't solve it. We...
Your solution will depend on what type of phone and headset you have. I have a Polycom 501 IP phone with a headset jack and a GN Netcom 9125. I'm not using the lifter right now, but I seem to recall that an easy way to make it work was to plug the curly cord of the phone's handset into the bottom of the base unit, so that the cord went from the base of the headset to the headset jack on the base of the phone.
Jul 11, 2011 | GN Netcom GN 1000 RHL Wireless Headset
The charging lights come on when the headset is placed on the stand then go out immediately. I put in a new battery but same problem. The headset is not working.
Seeing as you already ruled out a bad battery, it sounds like the unit has gone on you, GN Netcom does offer a full one year warranty on their wireless products, I would recommend calling your distributor, and seeing if you fall within the replacement range.
Jun 30, 2011 | GN Netcom GN 9330 USB Wireless Headset
My Headset just stopped working on the gn9350 headset. The base is on but it does not seem to be charging and there is no light on the headset or in front on the charging station. Is there some way to...
Hi I was in a live session with you when you left. Apparently you have not paired the headset with the base. All you have to do is follow this procedure
Place the headset in the charging base->Press the base's pairing button->Both the telephone and USB buttons on the base until the headset's link indicator will light for 2 seconds indicating that the pairing is successful. It should probabl charge after this.
Let me know if you need more help.
Sai.
Mar 17, 2009 | GN Netcom GN 9350 Wireless Headset
Setup
You can go online and download the operation manual for the 9330.
I saw it when I was looking for a solution to my problem. I do not remember the exact address. try gnnetcom.com/9330/support.
if that is not it try variations good luck
Jan 27, 2009 | GN Netcom GN 9330 Wireless Headset
Base unit cuts out and resets by unpluging and pluging in.
It sounds like your handset's battery is failing on you. How old is it? If it is more than a year or 2 old, you might want to replace it.
Nov 07, 2017 | Panasonic Cordless Phone Headset Headset
GN Netcom GN 9330 Wireless Headset Logo
1,844 people viewed this question
Top GN Netcom Radio Communications Experts
Tom Chichester
techmncpa
Level 1 Expert
MrFixitSTTL
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
