System dead sony mini hi-fi music system model sony rv 60 is dead. mains supply relay doesn't on
  • Anonymous Mar 18, 2014
    All other functions of the system work fine
Bypass the power from the main point after the capacitor via a 20ohms resistor...it may work.
Posted on Dec 07, 2007
LG FA 162 doesnt power on.
Dry electrolitic condensator on main power unit or short circuit on speaker cables
Nov 27, 2013 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
CD burned on my computer won't play back on my Sony Mini Hi-Fi Component System MHC-NX1. I'm using Memorex Music CD-R and the burned CD will play back on my other stereo systems.
you have probles with a driver try to unistall the driver on the cd or dvd burner and automatic it will install the driver the pc will look for the driver on c:hdd if the porblem continue call 956 400 4141 I'm a computer technician send me you info and i will repair you computer problem.
Nov 27, 2010 | Sony 720W 5-Disc Mini Hi-Fi Component...
Car cranks but dose not start, there is no power to distributator or fuel pump
I suspect the at this point, the main relay is defective. This relay controls power to fuel and spark circuits.
The PGM-FI Main Relay is actually comprised of two individual internal relays. When the ignition switch is initially turned ON , the Powertrain Control Module (PCM) supplies ground to the PGM-FI Main Relay. This ground triggers one of the PGM-FI internal relays that sends battery voltage to the fuel pump for two seconds to pressurize the fuel system.
When the engine is running the PCM supplies a continuous ground to the PGM-FI Main Relay. The supplied ground keeps the relay in the "closed" position providing electrical current to the fuel pump, keeping the fuel loop pressurized while the engine runs.
If the engine is not running with the ignition on, the PCM cuts the ground to the PGM-FI Main Relay, causing the relay to "open" and stop the electric current flow to the fuel pump. As mentioned previously, if the engine is not running, the PCM will only supply ground to the PGM-FI Main Relay for two seconds when the ignition switch is initially switched to the ON position.
The PGM-FI Main Relay also supplies electrical power to the Idle Air Control (IAC) Valve and to the fuel injectors.
TESTING
If the engine starts and continues to run, the PGM-FI Main Relay is working and does not need to be replaced.
  1. Locate and remove the relay.
On some models of the Civic and Civic del Sol it is located to the left of the steering column under the dash. Many later models position it either near the passenger right side kick panel under the dash or by the driver left side kick panel up under the dash.
  1. Attach the battery positive terminal to the No. 2 terminal.
  2. And the battery negative terminal to the No. 1 terminal.
  3. Check for continuity between terminal No. 5 and 4.
  4. If there is no continuity, replace the relay and retest
Aug 05, 2010 | Honda Civic Cars & Trucks
How to incrise the bass of sony MHC-RV777d
Is it possible that the speakers are out of phase, where one speaker is moving out, the other is moving in, resulting in zero bass?
Other than checking wires, making sure + on amp is linked to + on speaker, try changing the eq settings, or sit them next to a wall - walls help bass a lot.
Jan 08, 2010 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Sony Mini Hi-Fi Component System (MHC-RG660)
I understand the problem. It should be the relay which is not responding, technically not able to connect the system power supply, you will have to replace the relay. The STK chip should be working fine.
Aug 26, 2008 | Audio Players & Recorders
Cassette Stuck in Sony Hi-Fi RV-888d
Actually when audiotape struck (Click-Click-Click), rewind and forward 2-3 times or manually rewind and forward 2-3 times with the help of pen. After you can play the cassette
I am also use the same music system (MHC – RV 888D)
Mar 21, 2008 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Game video input enabling
Dear krismedia
You should first confirm that Audio/Video output cable from the hifi is connected to the TV , then you should connect the game console to the input section in ur hifi system. And finally see if the TV is in AV mode and also see if the HIFI is detecting in the input mode.
Dec 12, 2007 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
78 people viewed this question
 Grubhead
Grubhead
