I have the IBM 4247 set up and have run several print jobs with it. When it runs, it runs beautifully.
When it puts up a 56 print error, I've got to admit I'm confused. If I run the exact same job again it goes through the second time. According to the user guide, I should be able to push the online button once to clear the error and then a second time to resume printing but that hasn't happened. It doesn't clear the error and I have to shut it down and restart the printer.
I have it in 2381 emulation mode with a parallel port connection to an Windows XP host that shares it (utilizing the IBM 2381 driver) to the network. It prints much much faster than anything else we have and I love the way it prints the reports fast and with a crisp appearance. I need to figure out where the 56 print errors are coming from so that it will be reliable.
There are a number of potential causes for this error. the most likely is a dirty Printhead Home sensor ( see Pic). Try cleaning it with a cotton bud or compressed air.
Does the problem occur during a self test ? ( print at leat 10 pages )
I have an IBM 4247-A00 printer with no documentation. How do I change the forms width to...
(More)
I have an IBM 4247-A00 printer with no documentation. How do I change the forms width to 132-characters? Thank You.
I have an IBM4247-A00. It has an Axis network print server (540+/542+) attached for tcpip n/w...
(More)
I have an IBM4247-A00. It has an Axis network print server (540+/542+) attached for tcpip n/w connectivity. In the set up of this server it is currently set up as laserprinter. I believe that is the default. What should it be? Thanks
After an IPL on the Iseries, our 4247 printer will not connect back to the ip network with out power...
(More)
After an IPL on the Iseries, our 4247 printer will not connect back to the ip network with out power down and back on. Is there is a setting that could fix this?
