Question about Bosch 24 in. SHU53 Built-in Dishwasher
Low water pressure
Pump pressure seems low, when I open door while running, spinner is not spinning. Unit is a little more than a year old. Suspect unpopped popcorn could be stuck somewhere.
  • 76 Answers
Take the impellors of (inside machine) and check to see if there is anythig clogging the wholes. Run the machine for a couple of minutes without impellors on and check around the sump and filter.
Posted on Dec 07, 2007
Karcher K2.54M loss of all pressure
I have seen it before where the little plastic pistons overheat and melt. The unit still runs but with no pressure. I would pull the pump apart and check the pistons.
Sep 03, 2012 | Dishwashers
My kenmore 665 dishwasher will not pump water to the lower and upper spinner arms. The pump entry screen assy seems to have one tear in it and is dirty. However water does come out if I take off the lower...
Good eye--- Pull kick panel and look underneath. use a bright light to see if there is any drippage or what looks like corrosion on bottom of aluminum motor case. If you see this crud, then motor/pump seal has failed and motor is bad. About 100 motor/100 labor. Let me know if info helps- ED
Mar 02, 2010 | Kenmore Dishwashers
Wash Arms not spinning --Dishes not clean
Without the model number of your Maytag number, I can not determine if when you order a wash pump motor you also get the impeller.
Sounds like you are on the right path to getting your dishwasher to wash dishes again.
Oh, while you have the dishwasher open, check that the heating element has not failed using a Multimeter.
Good Luck!
Feb 01, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Pondmaster 250: Impeller or motor broke?
pondmaster 250 comes with a 3 year manufacturer warranty you should just exchange it for a new one. Overheating from low water sounds like the issue but as long as the shaft and housing are not scarred from debris they will replace without any questions
Nov 29, 2008 | Danner Pond Pondmaster 250 Gph Mag - Drive...
GE toploader Washing Machine pumping problems
Sounds like the water is syphoning away due to the drain outlet hose being too low..Raise the hose higher, and this should solve the poroblem.
Oct 31, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Detergent holder door problem
no this means that your bottom arm of the machine is not working correctly and the water pressure therefor is to low to get the soap out.
Clean lower arm (spinner) and all filters. You will see that will help the problem
May 04, 2008 | GE 24 in. GSD4020Z Built-in Dishwasher
Bosch shu3036 upper arm with low pressure
check water level should just appear above filter failing that a common fault on these is the impellor wings have worn you need to strip wash motor down to get impellor cover off
Jan 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Frigidaire Dishwasher FDB1050REC1 - Washing Indicator Light Blinking
Here is what happened, you pulled the door open without pressing cancel and allowing it to pump the water out, hence the "flooding in the bottom". This is just one reason why it maybe blinking, there is a water sensor in the bottom. If your dishwasher is hooked up properly to any decent garbage disposal, run the disposal for about 30 seconds to a minute. This should pump the water out, more like activate a light siphoning affect. It should work as normal. If you are not having luck with that, detach the DW drain get it low and let it siphon.
Jun 26, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
Bosch 24 in. SHU53 Built-in Dishwasher Logo
83 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
