Question about Averatec 3200 Notebook
Screen just turned off
My computer was on and I placed it aside to take a call. When I looked back the screen was blank but the computer was still on. I tried restarting and the computer starts, the screen is just not turning on. It's not that it is black it's just not on. Did I hit a button or has my screen died? What should I do?
  • 38 Answers
On each laptop there is a power saving button to save power when you close the lid.You might have accidentally hit that switch.
Just try finding out where that switch is and manually try to make it on.
Posted on Dec 07, 2007
Why does my screen turn blank after a call is placed on my lg306g ?
Try not to cover the proximity sensor.Are you using any kind of plastic cover or case that might be blocking it? When you're on a phone call and to avoid 'cheek dialing', the screen is supposed to turn off and turn back on when you put your phone away from your face.The bottom button in the middle, by the way, is called the HOME button.
Maybe Its the proximity sensor. Try compressed air from your nearest computer shop and spray into the holes around the speaker.
Sep 09, 2014 | LG Cell Phones
Touch screen not working
It could be a connection problem. Try this steps:
1) Turn off your Ericsson, then turn over the unit. Slide down the battery door and pull it off the unit. Lift the battery out of its compartment and set it aside.
2) Run your fingernail along the seam where back cover meets the body of the unit to pop it out of place. Remove the back cover and set it aside.
3) Remove the two screws from the top corners of the back of the phone.
4) Turn your phone right-side up and run your fingernail along the seam where the front cover meets the body of the phone. Pop the cover out of place and set it aside.
5) Lift the keypad, located just below the screen, up from its side and place it to the side of the unit.
6) Remove the two screws on the metal plate just underneath where the keypad used to sit. Remove the metal plate and set it aside. The orange screen cable will now be visible just below the screen, connected to a port on the green circuit board.
7) Unplug the screen cable and plug it back in, making sure it is secure in the port. This should fix the connection problem with the screen. Reverse the steps for reassembly.
Jun 27, 2011 | Sony Ericsson P1i
My computer screen is black after logging in and i cant do anything i have windows vista
Hello
This usually occurs when your RAM is faulty and can actually happen to all computers running many different operating systems. Aside from installing a new operating system to test out the RAM, you can simply switch out your RAM.
Turn off your computer if it is on. If you are experiencing the black screen regularly, there is a good chance that it will not allow you to boot up your computer fully without shutting itself down. If this is the case, your computer is already more than likely off. Remove the power cord from the computer tower.
Remove the screws that hold the PC tower cover in place with a screwdriver. The tower cover usually only comes off on one side, so gently remove the side that is capable, and place it away from the tower. Users with laptops need to remove the RAM panel from the underside of the computer. This gives you access to the RAM for replacing.
Locate the RAM that is attached to the motherboard of your computer. You will see clasps that hold the RAM into place, and you may see more than one stick of RAM. Remove all of the RAM sticks by pushing the clasps away, unhooking the RAM from the motherboard. Click your new, replacement RAM into place, and cover the tower back up with the cover, or replace the laptop RAM panel.
Hook up the power cable or place the battery back in, and power on your computer. You now see that your computer is working without the black screen appearing. If you have more than one stick of RAM, turn the computer off, and remove the power cords and battery. Insert one old RAM stick, and cover the tower back up, replace the power cord or battery, and turn on your computer. Check to make sure it does not present you with the blue screen. One by one, reinsert the old RAM sticks into your computer, and test your computer for stability. Once you are presented with the black screen, remove the last old RAM stick that you inserted, and your screen problems are gone.
Nov 14, 2010 | Computers & Internet
Iwant to know how to install lcd screen
  • Place your cell phone face-down, remove the back cover, remove the battery from its compartment and set it aside.
  • 2
    Remove the Phillips-head screws securing the back panel of the phone. This portion of disassembly varies from phone to phone. Some cell phones require that you pry off the back panel with a thin plastic object such as a guitar pick or credit card. Remove the back panel and set it aside.
  • 3
    Remove the circuit board. This part of the disassembly process varies from cell phone to cell phone. Most cell phones require that you remove the screws securing the circuit board in place. After the screws are removed, you may be able to completely remove the circuit board, but many phone require that you disconnect one or several ribbon cables connecting the circuit board to the keypad, LCD screen and camera. Lift the circuit board out of the phone and set it aside.
  • 4
    Remove the now-exposed LCD screen. You may need to remove a few small Phillips-head screws. Lift the LCD screen out of the cell phone casing and set it aside.
  • 5
    Follow this procedure in reverse to install the new LCD screen into your cell phone and re-assemble the cell phone casing.
  • Oct 09, 2010 | Cell Phones
    Blank Screen
    Common problem in monitors are bad caps in the power supply, that is the first place to check, look for bad caps with bulging top/bottom, see example of failed VIEWSONIC monitors due to bad caps here (worst case will be bad lamps): http://s807.photobucket.com/home/budm/allalbums
    Post back what you see so we can help you further.
    Feb 06, 2010 | ViewSonic VG2230WM LCD Monitor
    Blank Screen
    Well it is possible to install a new screen relatively easily... It is a bit of a mission, Ya need to get a replacement screen & driver board and do the reverse procedure from removal. A screen can be got from say, Ebay, or the net. Otherwise get a reputable place to do it for you.
    Jan 26, 2010 | Acer Aspire 3610 Notebook
    Studio 15 screen blank
    there is an inbuilt hardware diagnostic..
    turn the computer off then hold Fn + power button to turn it back on.. it will automatically initiate PSA diagnostics.. will beep and ask you if u see the colour bar displayed.. if u see them respond accordingly or else.. let it run.. within 10 minutes you'll get an error if its hardware glitch.. call dell tech support at 1800-624-9896 and tell the error code.. they will replace the lcd kit by sending a tech at your place.
    Dec 19, 2009 | Dell Studio 15 Laptop
    Sceptre naga blue screen when tv on then turns blank, sound on
    i have a secptre t v turns on for a sec and screen is blue then goes to blank screen can anyone help
    Apr 18, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
    White blank screen
    <Fn> + <F6> Screen blank
    Turns the display screen backlight off to
    save power. Press any key to return.
    Dec 30, 2008 | Acer Aspire 4315 Notebook
    AOC lm929 monitor
    AOC LM929 or Envision EN-7100 removal instructions:
    DANGER!!! UNPLUG and allow the monitor to discharge before servicing.
    with a small flat head screwdriver, insert into the edge and pop open the small plastic
    pieces that surround where the stand connects to the monitor. put plastic pieces aside.
    lay monitor on soft flat surface front side DOWN. with a phillips head screwdriver,
    remove 4 screws in the center that hold on the stand. put stand and screws aside.
    lay monitor on soft flat surface front side UP. insert flat head screwdriver into the
    side edge of the grey plastic and turn screw driver so the plastic surrounding the
    screen edge pops up exposing an area surrounding the screen. put plastic rectangle
    piece aside.
    slide out plastic buttons piece from the side and put aside.
    with a phillips head screwdriver, remove 8 screws (4 on top and 4 on bottom) that hold
    the screen assembly to the back housing. now lift screen assembly out of the plastic
    housing. put back plastic housing and screws aside AND lay the monitor screen with the
    FRONT side down on a flat soft surface.
    with a phillips head screwdriver, remove 2 screws that hold on the metal electronics
    cover. slide the cover down and remove. put the cover and screws aside.
    USE CAUTION!!! Some components may still contain a charge.
    check fuse... whatever...
    Aug 29, 2008 | Computers & Internet
    Averatec 3200 Notebook Logo
    59 people viewed this question
    Top Averatec Computers & Internet Experts
    Rommel Balcita
    Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
