Question about Sony STR-DE545 Receiver
Rear Speakers After turning on the unit the rear speakers work (sometimes) for a couple of minutes, then I sometimes hear a click and they go out.
  • awsaq Dec 18, 2007
    My DE545 started to cut the rear channel and sometimes the center channel too. It certainly is not due to heat. The problem started few months back and then went away for a long time. Now, it is back and the click sound happens just after few minutes of playing. The amp is in a well ventilated location. I am going to take it apart and clean as described in other threads.
Update:
Took apart the boards and resoldered the Blue Relays. Now it seems to be ok. It looks like due to bad solder, the relay trips when the board warms up. Taking apart was relatively easy, several pluggable connections and many screws to deal with. I took a digital picture before pulling apart, so as to remember the connections. Also, had to remove the smaller boards to get to the big board at the bottom. The challenge is to solder, must be extremely careful to not drop solder on the board.
Posted on Dec 19, 2007
98 Durango Rear Speakers not working
look under back seat for preamp
Jun 01, 2012 | Cars & Trucks
Tip
Instead of resetting rear speakers each time.....
I have found a similar problem with the rear speakers on this unit (needing to be reset each time the unit was turned off), but found a quicker way around it.....with both the main unit off and the rear receiver off: turn on the rear speaker receiver, then the main unit. If the blue light on the rear receiver does not come on, turn off the main unit, and turn it back on again. This has worked for me ~50 times or so and has worked repeatedly. It's faster than going through the reset phase each time. Also when turning off the system, turn off the main unit first, and then the rear receiver. Sometimes I also simply leave the rear receiver on since it pulls only 4 Watts. Hope this helps any users.....(it also works on my boyfriends older generation model).
on Dec 28, 2008 | Samsung HT-WX70 Theater System
I have a Sony STR-DE845 receiver. The rear
Something is heating up to a point that it fails in the rear amplifier section. take it to a tech.
Jan 01, 2010 | Sony STR-DE845 Receiver
I can't get surround sound from my theatre system
Read your manual , there is a level setting for each channel as well as a test function. Also remember most media on pro-logic mode dont have to loud sound from the rear speakers. Only a forced mono mode may give you louder sound at the rear. Regards PSP
May 12, 2009 | Audio Players & Recorders
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
Receiver clicks and rear speakers stop working
Maybe, it worked for me. my rear speakers workt ramdomly, often not. so i re solder the relay for the rear speakers, now it works fine everytime, a hole movie and some random on and offs, it can't do any harme to try=)
Dec 09, 2008 | Sony STR-DE635 Receiver
Stereo problems
sounds like a speaker problem, but it could be the stereo itself. it could have a damaged circuit board. the only way to find is to test the speakers/head unit.
Sep 26, 2008 | 2000 Toyota Corolla
Speaker protection fault on rx-v557
Hello, you must first tested with a voltmeter in DC entrance if you have a DC voltage on all the terminal outlet speaker, normally you must obtain 0Vdc+/-50mV on each out speaker with control volume to minimum, you can stay or remove the speakers during this test.
BY
Sep 04, 2008 | Yamaha RX-V557 Receiver
2 channels not working on 4 channel amp
Well firstly are you using a parametric crossover with your radio and how much rca cables do you have coming you head unit (car radio) if you going to bridge the front up with you rear speakers u wont be able 2 hear the rear speakers try hookinking it up 2 your head unit's front speaker output and have ur rca cable connected to your amp running on your rear output of your head unit by doing this you can use your fader on your head unit to control your front and rear speakers
Nov 07, 2007 | Rockford Fosgate Punch 300X Car Audio...
Sony STR-DE545 Receiver Logo
63 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
