Question about LaCie (300770) 250 GB Hard Drive
Help me ! Lacie ED Disk Ethernet 10/100
My original My Disk is die, i change new hdd, but I can use only USB, can't use Network. help me. Thanks
  • MySugar Dec 10, 2007
    Thanks your support !
    But my problem not like that, i've "Lacie Disk Mini Ethernet 10/100", HDD Maxtor 250GB IDE, My HDD original is die, i change new IDE HDD, i'm using usb ok, but i can't not using Network, i don't know setup partition into it.
    Problem Solver:
  • 7 Answers
If you are using (sata)harddrive dont install windows 98.i have a solution now before connecting your harddrive change the jumper to the slave (for single harddrive and single cd-rom or combo drive).it will work.plz install windows xp (service pack 2) or windows vista these are good versions for all!
Posted on Dec 09, 2007
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Hi ,my name is sameer i have 120gb lacie external hard disk,but is not suporting usb cable how can i change case pls help.............
just open your external HDD case, look for the connector (SATA or IDE), so buy new external harddisk case according the connector type.
Dec 20, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
No access to the disk, same clicking sound + constant light
It may not be getting enough power. Is there an external power supply you can plug in or another USB connector that can be plugged in to another port?
Jun 18, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
How to recover data from lacie etherdisk when it does not keep a network conntection.
I'll have to look into it a little more but off the top of my head I would say that the nic may be going bad or some other component of the etherdisk. You can try opening it up and putting the hard drive into an enclosure and connecting it to a pc via usb to get the data, you can also then share the usb drive and use it over the network, however removing the hard drive may void any warranty you may have. If the hard drive is in fact bad then you should be able to replace it and then continue to use the device. I'll get back to you when I get more info about the device.
Sep 21, 2008 | LaCie Ethernet Disk (300788) 1000 GB...
Unable to locate Lacie Ethernet Disk Mini on the network
Lacie's out to lunch..you may be experiencing the old drivers are shot issues..get em from the main site, and reinstall, ok?
Mar 24, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Hard drive won't start up at all
Knowing LaCie the drive might need to be connected to a computer, or need a new battery.  If it is not the battery, try connecting the drive to your computer via ethernet or USB  and you might be able to get the data off of it
Jan 02, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Administrator password
default user administrator default password admin
Nov 07, 2006 | LaCie Ethernet Disk (300788) 1000 GB...
LaCie (300770) 250 GB Hard Drive Logo
152 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
