Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
Noisy air flow problem, I think
When compressor comes on emits a sound like blowing across a pop bottle, whooo, whoooing does not stop until freezer is shut down
  • Anonymous Dec 21, 2007
    I have the same problem. I thought this was an air flow problem myself and so I pulled the front panel off of the cooling coils in the back of the freezer in an effort to change the air flow to see if it made any difference in the noise problem. It did not. So I now think it must be the motor assembly (bearing, or some other vibration/harmonic in the motor assembly?) My next step is to remove the motor assembly and test it outside the freezer to try to replicate the problem.
  • TARANDY24 Aug 13, 2008
    MY GE FRIDGE IS ABOUT 2 1/2 YEARS OLD. THERE IS THIS ANNOYING WIND BLOWING NOISE THAT IT MAKES. IT USED TO BE NOT SO BAD, BUT IS GETTING WORSE AND WORSE. DOES ANYONE KNOW OF A RECALL ON A PART FOR gsh25jsrfss THIS MODEL. I HAVE READ IT COULD BE THE MOTHERBOARD. IS THIS HARD TO REPLACE AND HOW MUCH DO THEY COST?
  • 410 Answers
The GE refrig has a variable speed fan motor controlled by the mother board located on teh rear of you refrig. the noise your hearing is the fan speed ramping up and down. if this noise is constant its possible the contoller on the mother board is bad and the board needs to be replaced. hope this helps...
Posted on Dec 12, 2007
When engine gets to operating temperature noise from timing belt area whooo whooo, any ideas?
Sounds like water pump! If it was last changed 60k when timing belt done could need doing! If not timing belt tensioner! When timing belt is done it is good practice to replace water pump and belt tensioners at the same time!
Oct 23, 2014 | 2002 Nissan Frontier Crew Cab
Whooo noise coming from the rear
Have you had the tires checked out ?
Feb 18, 2014 | 1998 Chevrolet Malibu
G16sarxxf noisy fan from back bottom of fridge but no cold air coming from fridge or freezer
Hay Jeremiah , sound like your compressor fan is bad . the fan cools down the compressor so if its not blowing the compressor would overheat and shut off .
Good luck
AppliancesRen
Oct 26, 2013 | Refrigerators
Howling noise in HSS25GFP
I can only tell you of my experience when my freezer/Refrigerator made those similar sounds. I pulled it out from the wall and saw some dust accumilation so I took the bottom access panel off to the fan and compressor compartment. It had a lot of lint like dust accumilation so I cleaned it. I actually took my air compressor and blew it out.Made a little mess but nothing vacuum cleaner couldn't handle. Anyway it helped a heap. It's like any refrigerant device. The filter needs cleaning. Not sure it will help with your problem but it did mine.
Dec 21, 2011 | Hotpoint HSS25GFP Side by Side...
Compressor will not stay on no matter the temp. setting. After running a couple of minutes the unit emits a scraping or buzzing noise and compressor goes off.
Sounds like you lost one of your fans if air is circulating in the room its the condenser fan. Thats what blows across the condenser coil to the outside. It may just be a capacitor thats what helps the fan get started but usually if the fan is popping capacitors there is something wrong with the fan but at the same time capacitors do just go bad. hope this helps let me know.
Jul 23, 2011 | Frigidaire FAH126S2T Thru-Wall/Window Air...
I have a Whirlpool gold conquest side by side model GS5SHAXNL00 that has a clicking noise coming from the rear. The freezer isn't keeping things frozen but the fridge side is nice and cold. I can hear the...
These models have two fans. One is located inside the unit. The fan inside blows air across the cooling coils. With the door open this fan is usually running other than defrost cycle. If this fan has stopped it will cause the compressor to overheat and the relay will cycle.
The second fan equally as important is located under a fiberboard cover accessible from the back of the unit at the bottom. This fan is usually noticeable by an air flow sound. Usually air flow is detectable out of the front grill. If this fan fails to operate, blocked due to a major build up of lint the compressor will overheat and cycle as you hear,
Hope this helps?
This is the fan inside the freezer.
Jun 25, 2017 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Freezer not cold.
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
Hope this will help in solving the problem.....
Oct 07, 2010 | Frigidaire Refrigerators
1998 mazda millenia, the rear end slides
I need to know if you have any type of air suspension. If you have a air compressed shock system then I would say the whoo whoo sound is coming from a leak or problem in the air pressure regulation system. That could cause the sides to move up and down and loose your grip also. Have your suspension checked and have your breaks checked also.
May 31, 2009 | 1998 Mazda Millenia
Noisy Compressor
either the compressor is under charged or it is near breakdown. compressor cost is almost the 1/3 of the freezer cost.
May 08, 2009 | Haier HTE16WAA Top Freezer Refrigerator
In our 22 cu ft GE SxS fridge /freezer, the freezer fan speeds up and slows down frequently and creates a whoooing sound like a quiet hoot owl when reaching the peak speed of the speed up phase of the ebb...
I have had some of these units making noises like this. One I found was leaking water down from the water inlet tube and in behind the ice maker and behind another panel that shoots up to the ice maker and building up behind that panel and causing a whistling sound. Removing the ice build up solved this one problem but couldn't find solution to the problem for the other. Dismissed it to change in the weather and expanding and contracting of the liner of the unit. Hope this helps.
Apr 08, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
124 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
