FixYa.com
Tags:
Quantum SDLT 320 External LVD  Super DLT Tape Drive
My Drive will not eject the tape (by 3 users)
posted by HerrmannGD on Dec 07, 2007
I have a Quantum SDLT 320 Tape drive.  The tape will not eject, the drive runs then clicks then I get the flashing lights of death and then it starts all over again.  Retrospect says the drive is empty and the drive will not eject.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Feb 11, 2008
unable to eject tape and all lights on the right side flashing
Comment by Guest, posted on Dec 19, 2007
Best Solution
posted on May 02, 2008
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I waited about 5 minutes and ejected the tape. It works.
Thanks for tips.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Mar 13, 2008
FixYa! (100)
creationvr
Rating: 100%, 2 votes
Turn off the tape drive. (Switch in the back of the unit. Wait 2 minutes and then turn unit back on. Tape drive should issue a write data command and then rewind the tape. After rewind completes the tape should eject. If it does not eject after rrewind completes than try holding the eject button for 5 seconds to attempt a "force eject"
Note: Do not repeatedly press the eject button as this can cause damage to the tape and the tape drive.
Can you Help with these Tape Drives problems?
Tape Drives
scanner
hi, I have a bright scanner s/n... Answer This...
Tape Drives
Legato Performance Issue
Performance of writing to tape... Answer This...
Tape Drives
DAT72 tape problem
I can't take backup of... Answer This...
Tape Drives
Quantum Scalar 50 Library...
we bought Quantum Scalar 50... Answer This...
Quantum SDLT 320 External LVD (000003616772)...
Stops during boot
When installing SDLT 320 on a... Answer This...
Repair Service
Find Tape Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
