LG Heat / Cool Window Air Conditioner with Remote - 7000 BTU
Problem for LG Heat / Cool Window Air Conditioner with Remote - 7000...
Frig stopped running.
By pennykendric on Sep 02, 2009
Put old frig in garage plugged into heavy duty extension cord then to gfi outlet.  Worked fine for about 4 hrs. Then gfi tripped and won't stay on. Used another heavy d. cord, same thing. Plugged all into outlet in house and frig still won't run.I am a female and am not familiar with what to do. Frig is old, looks like new, ran perfectly this morning. Is there anything I can look for to fix my problem. By the way, I checked out both outlets with my vacuum and both worked fine.  Thanks for any help.
Comments:
Sep 07, 2009
- Thanks for the info. Really appreciate that someone cares. Guess what, I fixed the problem. Turns out that you CANNOT, I repeat, CANNOT plug a frig into a gfi because the frig draws too much current. I fooled around with all the connections I could find on the frig including taking off the hinge to see that connection and then said a prayer, and plugged it into an outlet in the house with the extension cord far away from anything near the garage and IT WORKS. PK
Sep 07, 2009
Clarification Request
Posted by dave57078 on Sep 03, 2009
well this isn't really anything to try that will fix your fridge but I thought you might like to know that when moving a refrigerator you are supposed to keep it vertical at all times... if you lay it on its side the fridge needs to sit unplugged for atleast 8 hours before attemptting to use it..... has something to do with the oils in the compressor I believe...
Solution #1
posted on Sep 06, 2009
Not Rated)
Mr Scooter
Rank: Apprentice
Rating: 0%, 0 votes
Maybe over pulling more amps the the GFCI curcuit can handle. Check all the GFCI plug and verify if there are anything else plugged in. Including hair dryers and / or flat irons.
Was this helpful?
Yes
No
Popular Solutions for LG Heat / Cool Window Air
Questions and Unsolved Problems for LG Heat / Cool Window Air
Do you recommend LG Heat / Cool Window Air Conditioner with Remote - 7000 BTU?
Answer
Answer
the heat wont come on but the a/c works well it just started what can i do
Answer
how do i clean my window type aircon?do i need a technician or can i do it myself?
Answer
My heater will not heat,,, now is there something im not doing to i t?
Answer
my whirlpool window a/c unit runs part of the time. Problem seems to be in the ground fault plug... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air... Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
