Hi, can you help?? My Oven has not heat, the fan spins and the internal light comes on, the orange light on the temperature control also works yet the elements do not heat up. Does my oven have a hi-limit switch somewhere??
Thank you
Two things sharyn, first check the breakers. It is possible that one of two that control the stove tripped...they are in tandem. Shut them off and back on. If no fix: You'll have to remove and test the element. (if more than one element is involved here...it might be the thermostat) Breakers off, pull the element out and have someone take an ohm meter and test the unit. Still no good? Then it will be the thermostat or relay. Let me know what you find.
