-   my brother has had toshiba 50h82 it has a bow line on top and bottom of the screen and a couple lines going threw it. the color convergence will not allow me to adjust. so i was curious im pretty handy is it a fairly easy fix or should i just let a "professional" do it and if so what would be a good guestimate of cost-   Guest
Hi, you have a failed convergence circuit, you didn`t list model & chassis number so I can`t tell you which IC`s your set uses. this is not an easy job for a layperson that has never done this before, (requires removal of main board and un-soldering two large IC`s and replacing them) If you want more info ask away but be sure to give model/chassis so I know which set were dealing with, good luck, BMW Rider
i bought a 52 inch projector tv off a buddy a yr ago and the day the red change and now i just cant...
(More)
i bought a 52 inch projector tv off a buddy a yr ago and the day the red change and now i just cant seem to get it back.
When I first turn on my 65" tv the picture has a purple/pink haze. Once I turn it off and wait...
(More)
When I first turn on my 65" tv the picture has a purple/pink haze. Once I turn it off and wait about 5 seconds and turn it on the haze is gone.
I have a SP61MD10 61-inch DLP High Definition TV----IT stopped working--I think the Tube went?? any...
(More)
I have a SP61MD10 61-inch DLP High Definition TV----IT stopped working--I think the Tube went?? any advice on an inexpensive replacement Bulb?
Where can I find a digital input card for my RCA hd52w59 TV? The analog input works, but my HD...
(More)
Where can I find a digital input card for my RCA hd52w59 TV? The analog input works, but my HD digital input no longer works and needs replaced.
