Question about Tascam 202MKII Single Dual Cassette Deck
Cassette tapes I have some old cassette tapes that shut off the player because they are draging, is there any way to get them to play so I can record them?
  • 1,512 Answers
Try firmly banging the cassette onto a table top(with reels flat) a few times, then ff right through and rew a couple of times. this will layer the tape more evenly and hopefully allow the mechanism to play it. the takeup reel or autostop mechanism may be failing if the deck does not have enough torque to carry the tape and may require belts replaced or dried grease removed in the transport.
Posted on Dec 09, 2007
Why won't the door shut on my cassette player shut with a cassette in itwhy can't i get an answer to my question
I'm sorry, but it seems you may have a product that no one has any experience with.
But just to help in any way I can I will suggest reading your operational manual to make sure your inserting the tape correctly.
Or maybe your tape has reach the end of the roll and is automatically ejecting it?
Check that all other applicable settings are correct for insertion of a cassette tape.
Does your device allow a "recorded tape" to be played? Or does it only accept "recordable tapes" to be recorded? I do recall that cassettes have a way of being identified by a player as to whether or not it is a "recordable" or a "non-recordable" tape.
I probably wasn't the best help you could have got here on fixya, but I have exhausted my advise to you, as general as it may be.
If my advise wasn't the solution, please be patient or reword your question to attract the experts in the field of cassette recorders or music recording equipment. Different headings will be directed to the answering panels that are associated with answering those type of questions.
Good luck
Apr 04, 2015 | Brookstone Victoria Tunewriter III USB...
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
Question (not a "problem") -
Yes, you can. You need a cable (A 3.5 to 3.5 audio jack - you can buy it for a few bucks at your local store) that plugs into the Microphone jack in the computer and the Headphone jack in the cassette player. After that, use a recording software (Such as AudaCity) and select the input microphone as the recording device. All you have to do, is press Record in the software and push play on the player. Good luck and best regards,Yuri.
Jun 04, 2011 | Arcsoft ShowBiz DVD 2 (3265)
I have a Technics Double Cassette Deck RS-TR212. On the rear it has Output and Input connections. Output goes off to the Amplifier. Can the Input be used to record or play from a record Turntable? I have...
your receiver has (or should have) input and output connections,, your turntable needs to be hooked to the receiver,, then with the output cables that feed your cassette player you need to go, in to out and out to in ( receiver output to the input of the tape player, and out of the tape player to the in on the receiver, while playing a record if you hit record on the tape player it will record the record, depending on the receiver it will show you the meter readings for either the in or out,, they vary
Apr 11, 2011 | Audio Players & Recorders
Tried to play some old tapes back and could only hear the third track? any ideas
since it is cassete recorder,may be it has magnetize by your player the last time you play it and the result is erasure of 1st and secon track..maybe you should break the plastic cover 2 edge at the bottom of your favorite cassette tape
Mar 28, 2011 | Tascam Starter Pack for 4-Track Cassette...
Reorded tapes only play out one speaker
check your cables to the units channel that doesn't work, for breaks. Does the cassette player play back a pre-recorded tape okay? if it doesn't there might be a internal fault.
Check the wires to the tape head to see if one is off.
Jun 06, 2009 | Kenwood CT-201 Cassette Player Single Dual...
Cassette deck motor won't engage.
The cassette may be being inserted backwards. Yes, I've done that!
Dec 10, 2017 | Audio Players & Recorders
Sanyo DVD Player & Video Cassette Recorder - DVD-7200
dvd does not play but video cassette does...fixable???????
Apr 16, 2008 | Sanyo DVW-7200 DVD/VCR
RCA cassette recorder/player keeps shutting off. argggg
fast forward, reverse the cassette and fast forward again. if the tape is too tight the current sensor will always trip out the motor.
Dec 03, 2007 | Audio Players & Recorders
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
Tascam 202MKII Single Dual Cassette Deck Logo
151 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
