Question about Canon PIXMA iP3000 InkJet Photo Printer
Dimantle my canon pixma ip3000
Cold you help me to dismantle my ip3000, cause i have a false paper jam ...i tried many things for fixing but i haven't succeed i will be grateful if you give me the procedure for dismantling the ugly machine lol...
  • 2 more comments
  • Anonymous Dec 20, 2007
    There is an obstruction, perhaps a push pin, lodged in the paper path obstructing the paper feed. To get it out, we need to disassemble the printer to expose the obstruction.
  • 3000riot Dec 30, 2007
    I haven't try yet but i think i will try the night of december 31th lol..i want to know if the year will be a lucky year printer react like there is an obstruction so the only way to fix it is the dismantling it ....thanks mate for answering i will told you if i succeed ...the force is with me so i will lol i will beat the darth printer ......
    happy new year and my the force be with us against the darth printer
  • CAPRICH Dec 31, 2007
  • JoeKay Jan 05, 2008
    Having a problem with paper feeding. Have taken covers off (unlatching front was tricky). Can see that large rubber roller on right is feeding paper as far as the roller that advances paper under moving print head (just beneath row of small white rollers). This roller is not doing its part to advance the paper. Tried the Clean Paper Feed Roller procedure in the trouble shooting section of manual - no luck. I assume a motherboard problem which means the unit is scrap. Comments?
    An expert who has written 2 tips or uploaded 1 video tip.
  • 9 Answers
I had this problem yesterday with my iP3000, but it turned out to be my own fault. I had randomly pushed the control panel buttons, as I tend to do that with printers, while I was trying to quickly cancel a print job.
The symptoms:
roller wouldn't advance, a lot of noise like it was trying to advance, then two yellow light error flashes. I knew it wasn't out of paper.
By randomly pushing buttons, I clicked the Paper Feed Switch which toggled from top sheet feeder to cassette.
I downloaded the e-user's guide from Canon and learned what those control buttons are. I simply clicked the Paper Feed Switch and it toggled back to top sheet feeder. That fixed it for me.
Posted on Aug 10, 2008
First take side covers off.  Under the lid there are little slots with small arrows next to them.  One on each side. With a small screwdriver press in and down on tab inside. lift the top paper feed lid and under it at the very back look for the arrows, do the same to those 2 slots in the very back. That will let you remove the 2 side covers. Then on the back you will find two more arrows do the same to them and in front where the printed page is delivered you will find 2 more arrows that I don't know how to describe what to do with them.  Be creative and you will figure them out.  Then the top should just lift off and see if you can find the problem.  I don't know exactly your problem so I can't help you any more with that.                                                              When re-assembling be sure the top front and back parts line up correctly before you push the side covers back together.
Good luck.
Posted on Dec 27, 2007
How to Fix a Jammed paper
There should be a panel on the back where the power cord is that you can easily take off to get to the paper.
Jan 04, 2015 | Canon Pixma MX452
How I solve my problem, my printer canon ip1300 have some error service error 6000
try seeing if you have a paper jam. turn it off open it up move your printer ink holder over to the left. Paper or ink could have jammed in it.
Mar 03, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
It wont grab the paper to print
Paper feed problem:
Remove any loose paper in the printer.
Paper jams
85% of paper jams are caused by worn rollers .The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Feb 03, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
Canon ip 3000 photoprinter not working
things to check.
1. check for any paper that may have jam inside the printer.
2. check for open covers, back, top covers and close them properly.
4. check your power adapter if its giving correct voltage to the printer.
3. Try to move the ink cartridge to the left gently and return back to the right most part.
please let us know if this works.
Feb 07, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Paper goes in squint drags to one side and jams
In my experience the usual reason for this is something (obstruction) in the paper feed. Make sure you have a really good look right down inside the paper path as quite small objects will stop a correct feed. The fact that it is one side makes me thing something is in there. I have serviced printers before with coins, paperclips etc that have found a way in.
Nov 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon pixma ip3000 paper feed jam
try cleaning the rollers with alcohol, the tires are probably dirty and one side is not gripping the paper.
Jun 19, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Need help with printer dell 942 paper jam
Power off the Printer
Un Install the Drivers of the printer
restart the system
re-install the drivers
if the problem continues
1. check the printer data connector
2. Check the correct paper is loaded
3. Check the colou catridge status
Feb 16, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon Computer Pixma printer ip3000
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 11, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Paper jam on 1 side
at start paper jumps in gear pulls to one side
Sep 23, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
False paper jam warning on Canon Pixma iP3000 printer
I have been using the Canon MP180 PIXMA for almost three years now without a hitch until I received a paper jam warning which I could not resolve. I Googled "Canon PIXMA paper jam" today and landed on this site. I turned the printer upside-down and shook vigorously. Out popped a small pebble-like bit of concrete which somehow found it's way into my printer. I guess our hardwood floor installation on the floor above had shaken up some old plaster and concrete bits that had lodged in our drop-down ceiling from our 3rd floor bathroom renovation last year and this little ****** came through an opening in our rec-room (where the computer and printer are) drop-down ceiling. A very strange sequence of events, that I would not have suspected, but happy to say that your advice here did the trick and the printer is a tough and trustworthy little printer afterall! Thank you. Dan in Canada
Sep 24, 2006 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
1,008 people viewed this question
old marine
old marine
