Question about Ovens
Whirlpool microwave over the range model# mh7100xyb-o stopped working
Micorowave just quit during the defrost operation. also the fan and light does not work. first i checked the circuit breaker it was ok. i then checked for power to the electrical outlet. it also was ok. what can be the problem
  • Anonymous Apr 09, 2008
  • 196 Answers
SOURCE: Whirpool double oven shutdown during self cleaning operation and now is completely dead and the top oven door will not open.
Too bad someone didn't answer this sooner. Caused be poor air circulation in the unit. There is indeed a thermal fuse used in this unit. This problem has been around for a while and no real solution has been found. The closest "fix" is to remove the fuse, turn it around and only hook it down with the screw that faces the panel. The other screw hole is then bent to a 45 degree upward slant. This give the fuse a little breathing room.
Posted on Jan 26, 2008
  • 1314 Answers
SOURCE: Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
Posted on Jan 30, 2008
  • 338 Answers
SOURCE: Jenn-Air JMC7000 Microwave Stopped working
take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
Posted on Dec 01, 2008
  • 105 Answers
SOURCE: Circuitry may have gotten tripped during clean cycle. Oven will open and electronics work but neither element will heat.
baked control module for heating elements. if you have a volt meter, check for power when oven on, if no juice its the control element, if you do get juice then its the elements
Posted on May 28, 2009
  • 25 Answers
SOURCE: Whirlpool wall oven stopped working after power outage
Ouch...sounds like the control module is blown. Thats the electronic timer. I've known this happen on several occasions. Bad luck!
Posted on Jun 25, 2009
Whirlpool super capacity 465
You may have several things going on f1 e4 is a control board issue with the touch panel plug in into the control board disconnect and reconnect if this problem presist will need a control board and touch pad for the oven not staying lit there is a new oven igniter kit 8190618 unfortunately no good diagnostics for this problem good luck
Feb 18, 2014 | Ovens
Whirlpool self cleaning oven will not heat up after cleaning. Lights and fan come on but not the elements. I have 223 volts to is model number RS696PXE
Hello Ken, welcome to FixYa.
It sounds like the hi-limit safety thermostat may be tripped, the scenario you described is exactly how this would manifest
...that is the component that typically trips/activates during a self clean on many ranges. You shouldn't need to open the front control panel, but access is through the back. (this can also occur during power surges)
You'll need to slide the range/oven out from the cabinet. If you slide the unit away from the wall and unplug it you can check the hi-limit.
Based on the model number you provided it should be a non-reset type hi-limit or push to reset. If non-reset it needs to be replaced.
**Unplug the range from the wall first of first**
Once you remove the panel you will need to look for a switch/thermostat which looks like either of these...
(Not likely...unless model is wrong)
The replacement if necessary are available at "" or "" to name a couple.
Let me know how you make out. Good luck. I'll watch for your reply and if you need anything further I'll be glad to help in any manner I can.
Macmarkus :)
Oct 24, 2011 | Ovens
Whirlpool oven gas range is beeping and is displaying F5E1.
This is a problem with the door latch switch. You will need to remove, check for continuity with latch open no continuity closed should have continuity. If the switch has continuity with latch open replace. I have replaced quite a few of these over the years, they usually seem to go during a cleaning or right after the oven was cleaned. Enter your model # at for an illustration. The switch is inexpensive and easy to replace.
Mar 28, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Cold Whirlpool AKZ451!!
You may have had a surge during the storm. Check main control board in console for damage.
Sep 01, 2009 | Whirlpool AKZ159IX Oven
Self cleaning oven won't start self clean mode
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
OTR Microwave Magnetron Fan and Interior Light Run with Door Open
Could be a defective door interlock or control board.
Mar 06, 2017 | Ovens
Whirlpool electric oven problem
thermal fuse to board blows, relays turn fans off, the thermal cut out on rear of oven kills element. change both fuses, install new style oversized blower.
Sep 22, 2008 | Ovens
Microwave oven stopped working
This is most common in over the range microwaves. Cooking grease migrates into the door switches, resulting in the symptoms you list. Replace the door primary and secondary interlock switches and you should be cooking again. NOTE: be careful not to touch other wires! Even with the unit disconnected from power, if you happen to have a bad bleeder resister in the high voltage capacitor you can still get a nasty zap !
Aug 27, 2008 | Ovens
Whirlpool Over-the-Range Microwave Not Heating, Model #MH7135XEQ-1
This is not something you'd want to repair. You are better off getting a new one. It is a lot of work and a little risky
Apr 12, 2017 | Ovens
Ovens Logo
266 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
